topcat74 Force Sensitive
Posted: Mon Jan 17, 2011 5:22 pm Post subject: pug 1.9td conversion which flywheel and clutch |
ok, I have just dropped off the gearbox for rebuilding, went to town on it and gave it to Bears Motorsports to work their magic. Question that has cropped up is which clutch and flywheel is usually used when using a 2.0 box and 1.9td pug engine? Also from experience have any of you guys had to alter the input shaft length on the box?
Any help appreciated,thanks |
famous phil Jedi Guardian
Posted: Wed Feb 16, 2011 11:01 pm Post subject: Re: pug 1.9td conversion which flywheel and clutch |
| topcat74 wrote: | ok, I have just dropped off the gearbox for rebuilding, went to town on it and gave it to Bears Motorsports to work their magic. Question that has cropped up is which clutch and flywheel is usually used when using a 2.0 box and 1.9td pug engine? Also from experience have any of you guys had to alter the input shaft length on the box?
Hi Topcat , best clutch to use would be a 228mm 2.0L lawn mower/1.9L waterboxer , the VW flywheel should be mounted to the Peugeot flywheel
There should be no alterations to the input shaft
what year vehicle have you removed the engine and box from ? _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
Posted: Tue Mar 15, 2011 4:17 pm Post subject: |
Hi and sorry for the late reply.
The engine is from a N Reg 405. Looking at your post you say the pug flywheel should be bolted to the vw flywheel?
Gear box now back from bears and looks fantastic. Its had taller 3rd and 4th gear to help with the top end cruising speed. |
