Hesitation issue no 2!
Griff71
PostPosted: Thu Nov 18, 2010 1:24 pm    Post subject: Hesitation issue no 2! Reply with quote
I did carry on from Inanes previous post but my issue seems to have got worse. I have a annoying problem where my engine seems to be running on 2/3 cylinders or i am running out of fuel, no power/acceleration whatsoever then suddenly while my foot is flat to the floor it will kick in full pelt. Happens intermittently and if it wasn't for the engine running sweet in between i would have put it down to serious internal failure and started stripping the motor down or looking for another. I have said before i have done some serious miles on my conversion so i reckon some parts are possibly giving up. Did head gaskets earlier this year and heads, pistons and barrels are 100%
Previously i had a knock sensor error so i have replaced the sensor as it was cracked and fitted another. However error will not go away. Similar symptoms to what i had when i had a faulty sensor but like i said the problem is intermittent and not constant as with a faulty knock sensor. Again don't reckon there is any major issue as motor runs sweet as. However could the exhaust cause a fault with the knock sensor?
My theory: My exhaust is now coming on for 3 years old and it was a bit of a bodge when i built it but it has served me well. However it is nothing more than a seive in places and i appear to have thrown a stud out of the head/manifold flange. Now i would assume it would run like a pig anyway but would not expect symptoms like this unless the lambda sensor is being interupted by increase air, etc and telling the engine there is a problem.
Is this likely before i start fabricating a new system. Or has anyone experienced/solve a similar problem.
Thanks
Griff
89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock)
Inane Cathode
PostPosted: Fri Nov 19, 2010 3:13 am    Post subject: Reply with quote
Mine's back up and doing it again now that it has gotten all wet all over with the recent snow. I'll be watching this thread too :/
PostPosted: Fri Nov 19, 2010 6:29 pm    Post subject: Reply with quote
Running on 2, coil's dodgy or the signal to it. Total loss spark ie fires both opposing cylinders at TDC & BDC
Running on 3, dodgy lead, plug, cap or gap. Maybe mechanic failed to reconnect all 4 leads after doing work (HG's in my case *blush*)
I did get a wet lead at Putsborough one day and it caused no 2 to go AWOL on me.
Eyeball your plugs first, maybe replace.
Griff71
PostPosted: Mon Nov 22, 2010 1:52 pm    Post subject: Reply with quote
Have checked plugs and all seem ok, have a spare Coil Pack which i could try. Not sure about Inanes situe but like i say mine is intermittent.
I will sort a new exhaust system and check my Lambda sensor is working in first instance. Just wondered if exhaust was likely to be the source of the hesitation as it seems a bit extreme that a blowing exhaust would cause an intermittent issue and would not run like a bag of s*** all the through the rev range and all of the time?
Seems like i have had no end of trouble this year.
PostPosted: Sat Dec 18, 2010 4:41 pm    Post subject: Reply with quote
If it is worse in wet weather, it'll be an ignition problem on the HT or LT side. Damp in the plug leads, coil, ignition module, or spark plugs (if the ceramic has cracked) all give the symptoms you mention, with no error codes. If it's a problem on the HT side take it somewhere very dark (away from street lighting), and you may be able to see the sparks escaping from somewhere before they get to one or more cylinders.
Griff71
PostPosted: Thu Dec 30, 2010 9:42 pm    Post subject: Reply with quote
Have reworked exhaust and refitted/rewired lambda sensor as one wire had snagged. Plugs have all been out and checked and now seems to be running sweet.
However i have my ever occuring temp gauge flashing on and off intermittently from cold to running temp. Gauge creeps up when cruising and returns to centre at idle??!! Gauge has been fine the last few months and has now returned to annoy me.
Obvious done checked level, leaks, fan and flow. Even done a block test just in case HGs were suspect yet again. But everything is fine. So i am considering ditching the VW gauges all together. Seems the Impreza boys fit after market water and oil temp/pressure. So reckon i go this rout rather and get a genuine reading rather than messing with stock gauges any longer.
PostPosted: Fri Dec 31, 2010 2:56 am    Post subject: Reply with quote
Can't help here fella. Haven't got a scoobie about your watercooled *spits* Wink gauges etc. Soz
