Flywheel fitting advice?
ping
PostPosted: Mon Dec 06, 2010 7:28 pm    Post subject: Flywheel fitting advice? Reply with quote
Ok i fitted my flywheel today to my ej20 engine from an auto car. I fitted the bolts and torqued them up with no washers etc. Should i have used that round washer plate?
B4Tfink
PostPosted: Tue Dec 07, 2010 12:34 pm    Post subject: Reply with quote
are you talking about the torque converter plate the same size as the flywheel? then no ..
Also have you used longer bolts as the flywheel is thicker than the auto torque plate so requires longer bolts? (i have a part no at home for them if you require) i also used loctite as didnt want those buggers coming undone!!
1988 T25 EJ25 n/a.. it just makes more sense that way..
ping
PostPosted: Tue Dec 07, 2010 2:18 pm    Post subject: Reply with quote
I used the longer bolts that came withe the Kenedy flywheel. I had a long think about washers ind decided they are not needed as the bolts have been done up to 55 foot lbs. Cheers.
ydeardorff
PostPosted: Wed Jan 05, 2011 11:31 pm    Post subject: Reply with quote
So when going from a motor with an auto flywheel to a munal flywheel one needs longer bolts too?
Ive seen the 12lb kits on Fleabay, figured Id look it up too.
Anything specific else needed?
Sterling Kit car (VW based) Project
Current donor car and engine:
2005 WRX Turbo
Looking for 200 to 250HP lump, Found it = WRX
Joel
PostPosted: Thu Jan 06, 2011 12:10 pm    Post subject: Reply with quote
Yep, caused probs for me.
My donor was auto so i bought some longer high tensile bolts but the heads were too big
had to get correct subi ones from a subi shop
