splitbusvanatic Jedi Master
Posted: Mon Jan 03, 2011 8:35 pm Post subject: T25 1.6 Diesel Gearboxes.. 4 Speed vs 5 Speed..??? |
All I need to know Is?
Are they much different in actual size..
Is the 5 Speed Box much Longer..???
Thanks in Advance..
D.C. |
Alex (FTS) Jedi Guardian
Posted: Tue Jan 04, 2011 3:20 pm Post subject: |
I don't know about fisical size but I was told that both gear box's have the same top and bottom gear its just the jumps between them are smaller so you don't actually gain any advantage on gearing apart from a smoother shift.
Not sure if that's relavent to you but I just thought I would mention it just in case.  _________________ www.faltownskateboards.com |
Posted: Tue Jan 04, 2011 4:20 pm Post subject: |
Ok cool,,,
It's the Actual Size I'd like to know..
Reason Being,, A Guy I Know is making up a Cable Change Setup for T25 5 Speed Boxes.., I have a 4 Speed and He is having difficulty making the setup to suit my box,,
Different throw for reverse or something similiar.. |
Posted: Sat Jan 08, 2011 5:05 am Post subject: Re: T25 1.6 Diesel Gearboxes.. 4 Speed vs 5 Speed..??? |
| splitbusvanatic wrote: | All I need to know Is?
Thanks in Advance..
D.C. |
the 5 speed box is a bit longer in the nose area but this shouldnt matter if you have a 4 speed diesel box as they are mid side shift, some earlier 4 speed petrols can be nose shifting (totally diferent) but not a diesel box _________________ 1964 rat 13 window deluxe 1Z tdi,
