exhaust silencer/pipes?
troy_1234
PostPosted: Wed Nov 24, 2010 3:40 pm    Post subject: exhaust silencer/pipes? Reply with quote
hi im doing a ej20 into a splitty conversion, what diameter exhaust pipe should i use? and what sort of size/specification silencer do i need? is there a law which governs it? also what diameter coolant pipes?
thanks, troy.
PostPosted: Wed Nov 24, 2010 3:47 pm    Post subject: Reply with quote
http://www.vwkd.co.uk/bb/viewtopic.php?t=288
I've now used some SS from Jetex, rear box is now from a Caviler, maybe Vectra, £38.
Main coolant pipes 38mm I/D (IIRC) Holds approx 1litre/metre
Heater 15mm I/D (plumber's copper fittings are your friend along with rubber tube)
