Building myself a new engine HDi MHDi
famous phil
PostPosted: Wed Jun 16, 2010 9:24 am    Post subject: Building myself a new engine HDi MHDi Reply with quote
Happy Picked an engine up yesterday and removed the remaining common rail injection gear that was left on the engine , then machined one of the pump brackets mounting points from a D Turbo engine as only two bolt positions lined up one more to sort out before running ,
I built the MTDi pump for this job a while ago using a late 115brake VAG TDi pump , just need to find some better injectors , also got a few sets of injectors but not totally happy with them so will search a bit more whilst also looking for a VNT turbo unit
you can just make out one of the tried injectors BMW 320d these are a little tall and not too good to hold in position
vittesse_tuning
PostPosted: Sat Aug 14, 2010 2:26 pm    Post subject: Reply with quote
hows this coming along phil
famous phil
PostPosted: Fri Aug 20, 2010 8:38 pm    Post subject: Reply with quote
Hi, it's going well , now fitted into my camper and will be giving it a run out tomorrow ,
quick video of the first start
famous phil
PostPosted: Sun Sep 19, 2010 9:45 am    Post subject: Reply with quote
Finally had some more time setting up the fuel pumps , I'm using one now based on the rover 25/200 45/400 2.0L , this type of pump rotates the wrong way but is set up for a 2.0L and uses an 11mm plunger & head with less lift on the cam plate than the VW TDI pump so will be good for higher RPM's ,
Basically the cam plate was replaced with one of the same lift with the correct rotation the advance piston + springs reversed
main plunger dialled in and new drive slot spark eroded in a position so it lines up for the correct rotation replaced the cam plate 180 degrees out so the locating bolts line up for when changing cam belt and firring order corrected ,
This pic shows the old exhaust system , it's now a couple of inches shorter due to turbo position
main plunger with new slot
The temp senders on the HDi engines are a different thread diameter and pitch to the XUD9's and left no room for me to make an adaptor to fit the vw sender with M10 x 1mm thread , or my after market temp gauge , but when looking on a stall at Vanfest I noticed on a stall with many new parts which included temp sensors for T25 /T3 syncro only- I bought one because it looked so close to what I needed - I was correct , the pic below shows the temp gauge being checked ( both sensors were placed in a kettle ),,
few vids of it now ,
