troy_1234 Force Sensitive
Posted: Thu Oct 14, 2010 9:49 pm Post subject: just a quick clutch question |
hi im about to embark on a subaru conversion in my split, i got an ej20, mounting to an AT code gearbox... now if i get a kennedy 200mm adapter kit, will i just need to buy a standard 200mm clutch?? £80 type jobby from machine7? or a specific one from kennedy? im a bit confused.
any help would be brilliant, thanks, troy. |
Posted: Thu Oct 14, 2010 9:51 pm Post subject: |
| its a 2000 year by the way |
Inane Cathode Jedi Knight
Posted: Fri Oct 15, 2010 1:23 am Post subject: |
| Yeah, just stock vw clutch stuff. You really need to get an upgraded pressure plate and a more resilient clutch, though. I have some slippage and thats with a ej22 non turbo. |
Posted: Fri Oct 15, 2010 9:33 am Post subject: |
| cool thanks, so where do i get an upgraded one? could you give me a specific cause i really have no idea about clutches! thanks again. |
Posted: Fri Oct 15, 2010 3:56 pm Post subject: |
I got my clutch stuff from lawn mower.net they suggested the kennedy stage II pressure plate and the copperhead clutch disk (both in 200mm).
I thought i'd be alright with a heavy duty pressure plate and the KEP gold clutch disk, but alas mine slips if you drop the clutch on it and keep shifting hard. I guess 'heavy duty' doesnt really mean much. |
Posted: Fri Oct 15, 2010 4:04 pm Post subject: |
a.i.r.c.o.o.l.e.d.DOT net
If you type a1rc00led on here it becomes "aircooled" _________________ The advice you receive on here is worth the paper it's written on.
Posted: Fri Oct 15, 2010 10:23 pm Post subject: |
Couldn't resist
now we have a secret way to type aircooled  |
Posted: Sat Oct 16, 2010 12:04 am Post subject: |
Git  _________________ The advice you receive on here is worth the paper it's written on.
Posted: Sun Oct 17, 2010 12:35 pm Post subject: |
| thanks for the replies, so what set up do you think would be most suited for an ej20 to AT beetle box, pushing a bus? |
ping Jedi Master
Joined: 11 Aug 2008 Posts: 254 Location: Warwickshire
Posted: Mon Oct 18, 2010 8:41 pm Post subject: |
| I've got a kenedy clutch black with gold bits in and a kenedy stage III pressure plate. This is going in my split on an AT code gearbox. Dont forget to put in a heavy duty clutch release arm any poly bush! |
Griff71 Jedi Knight
Posted: Mon Oct 18, 2010 9:51 pm Post subject: |
Alternative to what ping suggests is chuck some more weld around the the clutch release shaft forks (the ones that hold your thrust bearing in situe). After having one break and following advice from Rich RJES that it is common. I welded mine all the way around the forks. I think VW had a single blob of weld on each side and Just Kampers even less.
It will break sooner or later![/img] _________________ 89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock) |
Posted: Mon Oct 18, 2010 10:43 pm Post subject: |
thanks again for the replies guys, will be sure to weld that release fork up then . am away at uni at the moment so will keep my eyes peeled for a second hand deal i think.
troy |
