Nath Force Sensitive
Posted: Tue Sep 14, 2010 6:02 pm Post subject: FOR SALE: COGBOX BUILT IRS BEETLE BOX, QUAIFE ATB |
NO EXPENSE SPARED GEARBOX
3.78, 2.06, 1.48, 1.04 3.88 r&p
Heavy duty internals, steel selectors, erco heavy duty side plate, porsche drive flanges, quaife torque biasing differential. Split screen nose cone fitted for use in early beetles.
NEWLY BUILT FROM COGBOX....NEVER FITTED!!!!!
£1800 ono. |
fastbackaru Wannabe
Posted: Mon Sep 20, 2010 5:51 pm Post subject: cogbox gearbox |
| hi nath have you still got the box if so what hp do you think the box will cope with cheers |
Posted: Mon Sep 20, 2010 6:01 pm Post subject: |
hi,
pete at cogbox said it will be fine for 200hp, more than that and you'll need a chromoly 1st/2nd shaft. But this really depends on the weight of the car and tyre and what you're planning to do. |
Posted: Mon Sep 20, 2010 6:08 pm Post subject: |
| 200hp is if you we're to drag race with slicks...but the cv's are likely break first. Let me know if you need more info. |
fastbackaru Wannabe
Posted: Mon Sep 20, 2010 7:02 pm Post subject: cogbox gearbox |
| thanks for the info i'm just after a box for a 71 fastback running a ej20 scooby currently on a bog standard box which kind of limits you which is a shame when you've got that power on tap think its running about 250hp but i have no evidence of this as yet i only want to run the car on the road not strip days as yet what do you think. |
Posted: Mon Sep 20, 2010 10:25 pm Post subject: |
| that kind of power will be fine for road use, even a bit of strip action - it's trying to get the front wheels up on slicks that would cause a problem...but like i said, your Cv's are likely to break before anything else - but you would never do that on the road! |
fastbackaru Wannabe
Posted: Mon Sep 20, 2010 11:15 pm Post subject: cogbox gearbox |
| pm'd ya mate |
