trev Jedi Master
Posted: Sun Aug 08, 2010 10:18 pm Post subject: audi gearbox in a bus |
I've done a search and come up with nothing soooo....
can the longitudinal gearbox from a recent Passat/Audi A4 etc be used in a bus? I understand that the diff probably can't be flipped but the whole box could be if the breather was plugged and the box filled with oil and an expansion tank used.
would the engine bolt back on to the upside-down box or would an adapter still be needed? It would be a cheap way to a nice low-revving 5 speed gearbox. |
illzlee Jedi Master
Posted: Mon Aug 09, 2010 11:48 am Post subject: |
would the linkage not be back to front? could make for a very interesting gear change pattern  _________________ '79 Bay running citroen 1.9td and phat tyres! |
trev Jedi Master
Posted: Mon Aug 09, 2010 12:06 pm Post subject: |
small price to pay for a nice lazy fifth gear. You'd get used to it.
so are there any major pitfalls to a conversion like this? I presume mounting it would be interesting but with the engine supported by its own bar/mounts then just a nose mount would be needed, the engine and box could be fitted up as one unit. |
Posted: Mon Aug 09, 2010 7:34 pm Post subject: |
been done before was talking to someone at vanfest 08 who had done in with audi 100 box and a 5cylinder 2.2 petrol in a t25 he cut the last 25mm of the bellhousing flange and had it tig welded back on upside down _________________ 1964 rat 13 window deluxe 1Z tdi,
