Terry Wannabe
Posted: Tue May 04, 2010 3:59 pm Post subject: Type 3 Conversion |
I have a 69 sqback that I would like to put a Subaru motor in, has anyone had any experience with this that could offer some advice.
Thanks, Terry |
famous phil Jedi Guardian
Posted: Wed May 05, 2010 10:10 pm Post subject: |
Welcome ,
I've not personally but have seen one on the net ,
Might help if you could add which engine you were thinking of , or were you kind of wanting information before purchasing an engine _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
Posted: Thu May 06, 2010 10:02 am Post subject: |
Watcha
I think there's a couple of guys on Aussies who've done them.
ISTR that the engine sits very high and you have to raise the boot floor to accomodate _________________ The advice you receive on here is worth the paper it's written on.
Posted: Fri May 07, 2010 7:05 am Post subject: |
It's pretty easy to fit a water cooled motor into a type three. Plenty of room in the spare wheel well for a radiator, the engine bay is mahosive and can easily fit a quad cam Subaru motor in it with no cutting of the car, slightly different tal if you go for a turbo lump but only slightly. With enough effort you can run your coolant lines through the gearbox tunnel or you can run them beneath the car.
Is your squareback a pan scrapper slammed to the road? If so then I'd reconsider going for the Subaru motor. As mentioned above the subaru is a tall engine from the engine sump to the top of inlet manifold. If you fit the engine low enough to fit below your stock engine hatch you'll need to lift the back of the car a far bit to gain some clearance for the sump. But if you leave the chassis on the floor and raise the engine and gearbox to clear you'll be stressing cv joints and forcing the gearbox oil into the nose end and starving the diff of oil.
As above Aussieveedubbers is the best place for squareback conversions that I'm aware of. Few other places for notch and fastback conversions. _________________ Think......
Posted: Fri May 07, 2010 9:05 am Post subject: |
Posted: Sat May 08, 2010 12:50 am Post subject: |
Kai,
What beer/drugs are you on dude
2 hrs between posts (the same post)
Do we have a "stasis leak"?
No, I'm not messin'/ _________________ The advice you receive on here is worth the paper it's written on.
hansend23 Jedi Master
Joined: 04 Mar 2009 Posts: 333 Location: Washington state
Posted: Sat May 08, 2010 1:54 am Post subject: |
clay just put one in his fasty.that kid did it in two weeks.i was impressed.
he hit the pan,and now is shortening it. _________________ just do it! |
Posted: Sat May 08, 2010 1:55 am Post subject: |
Grab some shots please
How's your bug doing? _________________ The advice you receive on here is worth the paper it's written on.
Posted: Sat May 08, 2010 6:28 am Post subject: |
| ElusiveStranger wrote: | Kai,
No, I'm not messin'/ |
Nope I've not a clue what's happened there then.
Can't blame drugs officer ES..... I've been clean since the second night of bug jam 2002. I've choosen to forget the details.
Must be my evil twin brother and his hot tub time machine playin silly buggers. _________________ Think......
