So where is everyone getting there pipe work from ?
PostPosted: Fri May 14, 2010 2:28 pm    Post subject: So where is everyone getting there pipe work from ? Reply with quote
Just headed off to Bristol Hose with a nice big shopping list of hose bits and pieces I needed only to come back pretty much empty handed They were good for straight runs of stuff but were super expensive for any angles and oddities that I required.
Anyway here is my shopping list, where do you think I'll find what I need..
Charge Coolers Pipes (air)
2x 50mm ID Elbows
1x Straight Tube 400m to connect above elbows.
Charge Coolers Pipes (water)
4m (16mm ID!) Hose
2x Reducers 20mm ID to 16mm ID (to connect to bike rad)
2x summuts to cap off bike rad inlet/outlet used for expansion when on bike.
Other
300mm - 57mm ID Pipe for fuel tank.
Also need some other bits to connect my air filter up to turbo and t in breather.
Some elbows for rad with take off to expansion tank
4m Servo Hose
and so on and so on.
I'm thinking Ebay will be my friend for a lot of this...scrappy is also looking fave too Grin
cheers me dears
T2 turbo
PostPosted: Fri May 14, 2010 4:25 pm    Post subject: Reply with quote
Got all my stuff off ebay except the long lenth's of ally hose which i bought through work via an industral stockist Wink
PostPosted: Fri May 14, 2010 5:56 pm    Post subject: Reply with quote
eBay again fella.
I got everything from there.
I used nylon hose for my charge cooler but the hose connections are 12mm ID I think. If you Do go for the nylon hose ask the supplier for the metal inserts to allow you to clamp onto it. Paid like £25 for 30meters.
Be warned though all these silicone connections ain't cheap. The guy I used often has a ten percent sale on but I don't know how often. His products where branded ASH, automotive silicone hose... Sorry don't know his name.
My 19mm to 12mm straight reducers are £8 each Eeeek
PostPosted: Fri May 14, 2010 6:17 pm    Post subject: Reply with quote
Kinda figured it's gonna be a bit pricey but hey rather get new than have this happen to me again...
The one that's getting me atm is the 57mm Fuel Pipe cheapest I can find is 60 odd squid !!! only seems to come in meter lengths which is annoying as I only need 40cm... keep hunting I guess.
Evening on ebay coming up me thinks .. now where's me calipers
PostPosted: Fri May 14, 2010 6:40 pm    Post subject: Reply with quote
1 meter of 57mm silicone straight hose is about £25 on eBay.
Not that it's much use I've got 190mm of 55mm blue silicone hose if you want it.
Just send me your address, bank details and your pin number ok
PostPosted: Fri May 14, 2010 7:01 pm    Post subject: Reply with quote
Is it fuel hose silicon you've found on ebay? I presume I need the fuel stuff for my filler
PostPosted: Fri May 14, 2010 7:12 pm    Post subject: Reply with quote
I just had to shell out £46 for the fuel filler pipe for mine ouch!!
PostPosted: Fri May 14, 2010 8:07 pm    Post subject: Reply with quote
I never realised there was a specific type of silicone hose for fuel.
The ones I found don't list fuel as an application only turbo/ intercoolers/coolant etc.
Trying putting fuel into the search and you find samco hoses which are listed as fuel hose. £110 Per meter length but I bet your just paying for the Samco name on the hose.
PostPosted: Fri May 14, 2010 8:28 pm    Post subject: Reply with quote
this is the cheapest I can find and not samco
PostPosted: Fri May 14, 2010 9:16 pm    Post subject: Reply with quote
try siliconhoses.com
Also I would speak to pirtek (theres one in westbury) and sure theres one near to Bris. Since youre using diesel i would have thought any of the hose they use for hydraulics would be fine......or you can go for my table leg from B&Q approach...meaning you can use the original hose. think that was like £6 or something. would rather weld it at my house tho to save moving the welder :-)
also try Car builder solutions, rallydesign and Merlin motorsport.
PostPosted: Fri May 14, 2010 9:39 pm    Post subject: Reply with quote
Did you weld leg to tank or filler? Just checked out other places and this looks like it might do the trick
http://www.cbsonline.co.uk/ultra-flexible-fuel-filler-hose-57mm-2-fff57-562-p.asp
PostPosted: Fri May 14, 2010 9:58 pm    Post subject: Reply with quote
flexi pipe from CBS will work well with the tank being higher now.
welded to the filler so the steel pipe is longer.
surely you must have some pipe somewhere in your garage Laugh Out Loud
