BlackCosmos Padawan
Posted: Sun Apr 18, 2010 8:01 am Post subject: Engine advice.. |
| the vans been running fine,recently upgraded frt brakes and now it stops..but now im pretty sure ive done the crank as its knocking like a good un..is it worth sorting this engine or should i get another?? its a 96 wrx.. |
Griff71 Jedi Knight
Posted: Tue Apr 20, 2010 5:46 pm Post subject: |
Have you checked out some of the recon engines on ebay? I was very surprised at how little they were going for. Also some are exchange so you send your old one off and get your deposit back.
This is the way i think i will go when the day comes as don't fancy buying a donor and disposing of it again.
Alternatively i was talking to a guy who restores early impreza's who reckons they are the easiest of all to get parts for as he states they are a 'future classic' he has a very steady work flow to prove it and a workshop full of spares. After recently doing the head gaskets on mine it is obvious it is just like an old VW engine on a slightly bigger scale so relatively easy to work on. Why not give it a go?
Good Luck
Griff |
Joel Jedi Master
Posted: Wed Apr 21, 2010 10:30 pm Post subject: |
I'd just swap out the engine, you could spend a fortune fixing your existing one.
thats the beauty of the conversion once its in and running if the engine dies you dont need a donor car just an engine and swap everything over
when my first engine started having issues i just bought a straight engine, no loom or ECU
it was from a completely different model of car
my original was an aus spec 92 liberty and my new engine is a JDM 95 legacy.
just swaped over the intake manifold, alternator and my sump and exhaust system
plug it in and drive away
so cheap to pick up too, $550au and i was back on my way
cant do that with 150hp aircooled engine  _________________ 1974 1303 Germanlook Suba-Beetle
BlackCosmos Padawan
Posted: Mon Apr 26, 2010 1:32 pm Post subject: |
| is it possible to change twin turbo engine to single turbo using my ancillaries? |
