dono-van Wannabe
Joined: 19 Mar 2010 Posts: 1 Location: thetford norfolk
Posted: Fri Mar 19, 2010 11:18 pm Post subject: alfa conversion in my bay |
| hi need some info on putting my 16v alfa engine in my bay ie can i make the parts as have noticed that the gear box shaft lands short of the clutch plate. do i need to extend the shaft or extnd the flywheel with some sort os boss on the back of. please if some one could advise me on that would be great |
Posted: Sat Mar 20, 2010 3:01 am Post subject: |
I've split your post
Welcome fella.
Could you tell us what g/box your running?
Dunno if it's pertinent to you but check out Gerrelt's web site. Alfa flat 4 into a bug...
http://www.gerrelt.nl _________________ The advice you receive on here is worth the paper it's written on.
T25alfa Force Sensitive
Joined: 01 Nov 2009 Posts: 10 Location: Crowborough. East Sussex,
Posted: Sat Apr 17, 2010 9:40 pm Post subject: Alfa conversion |
Hi there, you need an extension boss on the flywheel (about 60mm by memory) My one uses a beetle 1600 flywheel that has been adapted. It runs a 200mm clutch. You also need a bell housing adapter plate. If you want to use the fuel injection then you need to mount the alfa timing wheel on the beetle flywheel as well, or you could go down the carbs route.
Hope this helps,
Tony. _________________ Running an ex-lawn mower T25 with a 1.7 16v alfa quad cam. |
gerrelt Jedi Master
Posted: Sun Apr 18, 2010 9:42 am Post subject: |
Cool, a new post in the Alfa forum...
So, you got any pictures, T25alfa ?
Maybe you could post them in the "Completed Conversions" part of the forum? _________________ homepage
VolksRomeo 13033 S 1.4 IE
_________________ |
Posted: Sun Apr 18, 2010 12:40 pm Post subject: Alfa clutch |
Hi Gerrelt,
I'll have a look and see what photos i've got and then post them. The camper is not an item of great beauty but well used. I've just trashed the clutch, don't suppose you know of a kennedy clutch anywhere?
All the best,
