1.9 under a stock t25 engine lid?
Zebedee
PostPosted: Sat Mar 27, 2010 8:16 pm    Post subject: 1.9 under a stock t25 engine lid? Reply with quote
Will a 1.9 pug td motor (or one from a Citroën zx with the intercooler fitted on top) fit under the engine hatch of a t25 and still shut or does it need to be modified?
I know it'll fit in a pickup because of the extra 6" or so of extra height in the engine bay.
PostPosted: Sat Mar 27, 2010 9:00 pm    Post subject: Reply with quote
my mate put a 1.9 non turbo from a 405 in his panel van and had to build a box into the engine hatch for clearance, similar to the south african 5 cylinder t25's with the storage under the bed
Zebedee
PostPosted: Sun Mar 28, 2010 10:20 am    Post subject: Reply with quote
Thought it wouldn't fit to be honest.
PostPosted: Mon Mar 29, 2010 7:08 pm    Post subject: Reply with quote
a turbo diesel motor with the top mounted intercooler would be even higher i imagine
Zebedee
PostPosted: Tue Mar 30, 2010 4:31 pm    Post subject: Reply with quote
Anyone got any dimensions from the centre of crankshaft pulley to top of engine?
illzlee
PostPosted: Tue Mar 30, 2010 8:39 pm    Post subject: Reply with quote
i'll have a look tomorrow, if i get chance and let you know
famous phil
PostPosted: Wed Mar 31, 2010 10:14 am    Post subject: Reply with quote
Happy you can swap and change inlet manifolds ( check shape of ports early squared off later oval ), if the engines fitted with an intercooler on top then this will need changing ,does not work in this position ,
I've fitted a 205td inlet manifold so no pipes over the top ,I'm due to fit either a rover 418/218td ( very low )or xatia manifold so that i can fit the intercooler in a better position ( not for long as building up a common rail engine ASP ) , my camper has the auto homes conversion that had draws above engine hatch ,removed draws- so this is the amount the hatch was raised some people lower the engine mounting bar and gearbox mount were it bolts to the body Happy
