T1 gear box users?
ping
PostPosted: Thu Feb 18, 2010 6:42 pm    Post subject: T1 gear box users? Reply with quote
How are you getting on with your gearboxes?
PostPosted: Thu Feb 18, 2010 8:00 pm    Post subject: Reply with quote
I ditched mine for a 915.
Tomasz
PostPosted: Fri May 07, 2010 8:26 pm    Post subject: Reply with quote
Mine is the 002 - 3 rib one and I'm putting it into a bug
Calm Bug
hansend23
PostPosted: Sat May 08, 2010 1:57 am    Post subject: Reply with quote
i got about 7500 miles outa the first one that was tired.im at 6000 on the second.you just cant do burnouts or be hard.be easy on it .i floor it but dont let it break loose.n stuff.
i drive it every day.
just do it!
Joel
PostPosted: Sat May 08, 2010 10:06 am    Post subject: Reply with quote
how you drive has a big impact on it
EJ22 with a stock SSP 1303 box
give it $hit frequently, but never break traction, still going fine
a mate is coming up 2 years with a stock box and a single turbo WRX engine, its fine, like hansend said just dont be breaking traction all the time
Tomasz
PostPosted: Sat May 08, 2010 1:20 pm    Post subject: Reply with quote
If I was gonna do my bug conversion again I would go for a standard box + super diff. It saves a lot of work and nerves, it doesn't save you money because you need to get some HD parts -gearbox mounts, starter, pressure plate etc but is easier to put the whole thing together. Parts are available in most shops for VW lawn mower cars. There is a different story if you convert VW vans, in this case I would suggest to stay with the 002 or 009 gearboxes + RJES bellhousing
Calm Bug
PostPosted: Sat May 08, 2010 1:36 pm    Post subject: Reply with quote
If I was to do it again then I wouldn't bother with the 915, quaiff atb diff, Kennedy adaptor nor the cable shifter system.
I'd just go straight in with a quaife 6speed box and atb diff with sequencial shifter.
Admittedly it's double the price of what I spent but it would amazing Grin
