Throttle cable query
currylager
PostPosted: Sun Oct 18, 2009 5:29 pm    Post subject: Throttle cable query Reply with quote
I'm at the stage now where the engine's bolted in, plumbed in and the exhaust system is complete. I have the wiring still to do, but i was also wandering what people have done regarding adapting the vw throttle cable (solid wire in my case) to fit the subaru throttle body?.
I have a throttle cable and sheathing which i robbed from a dead scooby but was looking for inspiration on what to do next. I am hoping the movement in the vw cable will be enough to open the scooby throttle fully too.
Advice pls
HMMM, dont know yet, but i'll have a go!!!!
doppelganger
PostPosted: Sun Oct 18, 2009 6:37 pm    Post subject: Reply with quote
personally ide buy a one piece cable from rjes Grin
vwdrc class rep
PostPosted: Sun Oct 18, 2009 6:51 pm    Post subject: Reply with quote
Here's the bits in my set up (bought it from Custom Off Road in Oz)
Right, it uses the stock vw cable to the torsion tube area. I had to slice through the vw steel throttle condiut.
The black conduit in the photo is a scooby one, this replaces the vw one from the gearbox area.
The additional cable (VW I thibk) is inserted and clamped to the now cut VW one using 3 solderless nipples.
Simples
HTH
hansend23
PostPosted: Sun Oct 18, 2009 9:43 pm    Post subject: Reply with quote
here is what i did.
the scooby cable to a made bracket welded to the body and the vw cable tube extended and i made a c clamp thing with holes in it for the cable to go through and it works very well.no more problems.
just do it!
PostPosted: Mon Oct 19, 2009 2:55 pm    Post subject: Reply with quote
I second that.
Only cause that's what I did. Nice clean simple mod.
Although I dunno the answer about vw pedal fully opening the Subaru throttle though. Can anybody confirm this?
doppelganger
PostPosted: Mon Oct 19, 2009 4:00 pm    Post subject: Reply with quote
[quote="Kai"]
mine does but as a rule the t25 ones dont quite do it
vwdrc class rep
currylager
PostPosted: Mon Oct 19, 2009 6:55 pm    Post subject: Reply with quote
Thanks for the info, i now have some food for thought Grin . I put the coolant in last night but unfortunately i have a leak from the caravelle heater unit in the back, so ill need to suss that first Sad
PostPosted: Mon Oct 19, 2009 11:44 pm    Post subject: Reply with quote
[quote="Kai"]
T2 doesn't. I extended my pedal linkage. Can't remember by how much, 20mm or so but don't quote me!
You can work it out roughly from this:
You can see the orig hole.
(LHD BTW, would imagine it's similar for a RHD)
Joel
PostPosted: Tue Oct 20, 2009 9:46 am    Post subject: Reply with quote
ive set mine up exactly like a standard vw carb
currylager
PostPosted: Tue Oct 20, 2009 7:03 pm    Post subject: Reply with quote
Thats a cool idea, my bus is an early bay which has a more complex throttle set up at the front compared to the later bays, i always struggled to get full throttle with the lawn mover lump, so perhaps modding the subaru throttle flap linkage might be the simplest solution Wink
I'm tryin also to keep the van as original as possible so if i have to sell it to a lawnmover fan at some point (god forbid) they would be able to convert it back easily, so retaining the standard vw linkages would be a good idea.
Still trying to fix that bloody leak at the mo, being a proper bitch
Joel
PostPosted: Wed Oct 21, 2009 10:17 am    Post subject: Reply with quote
thanks, that was my plan too, keep it as simple as possible and also able to get back to original with no effort
i had an aftermarket cable setup on my old supercharged vw engine and i was frequently having problems with it
that was why i wanted to run the throttle cable as close to stock as possible
currylager
PostPosted: Sun Oct 25, 2009 7:55 am    Post subject: Reply with quote
Joel, did you actually use the linkage off the vw carb and mount it to the scooby throttle spindle?, if so i'd better go and scrounge an old card off a mate Wink
