More stuff for sale.. clearout time!
Ghia
PostPosted: Mon Aug 03, 2009 1:35 pm    Post subject: More stuff for sale.. clearout time! Reply with quote
1 x T3 brand new double glazed rear window (with damage, needs repair to bottom corner) £25
T3 Crewcab rear side windows with seals. £60
A pair of Beetle Koni adjustable Shock rear absorbers for a Beetle with IRS (Semi auto, 1302/1303)
2nd hand but in good shape SOLD
One set of Porsche wheel bolts, factory stuff including locking bolts and the tool to match. In silver and ready to bolt on your Porsche wheels to your adaptors.
If you want to fit Porsche wheels, these are the bolts you need. £40.
T3 Limited Slip Differential in good working order (original factory equipment), £400.
T3 AAP differential, also know as a 4 pinion diff. It has 4 spider gears inside rather than the regular 2 and is stronger as a result. £60
Porsche Cayenne Turbo alloys, 18 X 8s with either 255/55/18s or 225/40/18s, your choice. There are 5 wheels. £180 including centre caps.
2.1 MV injection system for sale, inlet manifold including throttle body, injectors, fuel pipes and pressure regulator etc, remove from a good running engine. £80
2.1 MV distributor, cap leads etc £50
2.1 MV Airflow meter including air box, £80
2.1 DJ loom £40
2.1 DJ ECU £50
Early 1.9/2.1 Exhaust system, J tubes if you like. In good usable condition £60
Early exhaust silencer, was supposedly sold but messed around so back up for sale. £40. Also fits lawn mower engine and Type 4 engined Bay window vans.
Petrol Syncro specific engine bar, £30
Turbo Diesel Syncro bellhousing with both breather pipes, £100
Turbo Diesel Syncro Sump in good condition, £100
Turbo Diesel Syncro engine bars including engine mounts, £100
Turbo Diesel Syncro oil filler tube £40
Turbo Diesel Syncro engine/gearbox protection/bash plate, £50
Turbo Diesel airfilter housing with brackets and pipework, £40
K14 Turbo, £150. In good condition, will bolt up to JX exhaust manifold and work with stock pipework but is bigger than stock JX unit, great for getting the most out of your tuned JX, AAZ or even 1Z TDi.
JX exhaust manifold (2WD and Syncro), good condition. £60
JX Inlet manifold, £30
JX Flywheel and clutch £60
AAZ Turbo Diesel Fuel pump from low milage engine complete with pulley. SOLD
AAZ Injectors again from low milage engine. SOLD
H&R Cup Kit suspension package. This includes H&R 55mm lowered springs and Koni Adjustable shocks. This is a brand new kit, still in wrapping. Only selling due to change in circumstances. £650.
Complete Big bumper kit for T3 including Brand new front bumper, all fixings, side planks, rear bumper etc, the lot. Again only for sale due to change in circumstances. £500
Rear Blenders, factory items not repros. £100 the pair complete with Hella rear lights.
Front spoiler 5 piece kit. In good condition. £140
Front spoiler 5 piece kit, slightly scuffed etc £100.
Various Syncro Petrol and Diesel parts available, ring me on 07989 333437
A selection of gearbox parts, phone for what you need.
Some parts are in Leeds, some are in Aylesbury so can organise to post or meet up etc.
07989 333437
MG
Syncro16@hotmail.co.uk
1989 Syncro 16 2.5TDi Westfalia Conversion Limey
Ghia
PostPosted: Thu Aug 06, 2009 11:44 am    Post subject: Reply with quote
AAZ pump and injectors sold
Konis Sold.
MG
