familyvan Padawan
Posted: Sun Aug 16, 2009 8:00 pm Post subject: 1967 Vw Splitscreen Camper TDI 130BHP |
Vehicle & model: Vw Splitscreen Camper 11Window
Year: 1967
Engine details: 2001 Vw Golf Tdi ASZ engine code
MPG
1/4 mile time
0-60
Top speed
Cooling system details - Rads mounted under van two seat rads mounted side by side with brether pipe.
4 1/4" narrowed beam
312mm Vented discs from a 2001 Golf V6 Calipers
256mm Self adjusting rear calipers.
Remote Servo
Modified Type 1 gearbox
3.44 R & P
0.72 Fourth Gear.
Mk4 Golf Fuel Pump built into tank, Orginal Diesel fuel cooler in line.
Renault 5 turbo Charge Cooler and pump.
17" Brm Wheel. ( New Beetle)
Rear engine mount made from Vw Polo Engine mounts and a Type 25 engine Bar.
Electronic ECU had the security removed , Dash pod still needed.
Current Build Thread
http://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=23027
Cost of converstion : If you have to ask you cant afford to do it
vwfamilyvan@msn.com
