Engine removal!!!!
Griff71
PostPosted: Fri Jun 26, 2009 8:16 pm    Post subject: Engine removal!!!! Reply with quote
Trying to remove the subaru motor from my t25. Sure i have removed all bolts and disconnected water lines that would hold in place or restrict. However i can not get the motor to budge only a few mm at most. I have anothee pair of hands to help but even still cannot get it out. Have tried putting in gear and rocking but no joy. Anything obvious i have missed?
Urgent advise needed as i need motor out tonight.
Thanks
Griff
Bigbadbugga
PostPosted: Fri Jun 26, 2009 10:56 pm    Post subject: Reply with quote
is it a turbo motor?
I heared there is something you need to do to disconnect the turbo clutch.
I'm sure someone will be along who can give you more details.
Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing.
PostPosted: Fri Jun 26, 2009 11:48 pm    Post subject: Reply with quote
Might be the location pins being stubborn if it's not a turbo motor.
If it's not a specific RJES problem you're better posting to "Subaru Power" Wink
doppelganger
PostPosted: Sat Jun 27, 2009 8:00 am    Post subject: Reply with quote
sounds like we will find its a turbo or the stubborn pin ,i cant think of anything else Happy
vwdrc class rep
wackos00
PostPosted: Wed Jul 01, 2009 11:16 am    Post subject: Reply with quote
2 things I have learn't the gearbox and engine have to be perfectly aligned while supported otherwise everything is obber tight, also sometimes things need a bit more brute force!
PostPosted: Wed Jul 01, 2009 12:56 pm    Post subject: Reply with quote
Follow the link and you'll discover my experience of removing the Subaru turbo engine.
http://www.volkszone.com/VZi/showthread.php?t=451156&highlight=kai4130
