where?
ruby bay
PostPosted: Thu Apr 02, 2009 11:15 pm    Post subject: where? Reply with quote
hi all, does anyone know/recommend anywhere to get lengths of rad hose? ive looked several times on ebay etc to no avail. basically i am after 32/34mm inside diameter rubber hose to go from front to back of van in one hit, and back again(spare wheel rad). i could go down to 28mm copper piping but would rather not. thanks in advance, mike.
PostPosted: Thu Apr 02, 2009 11:31 pm    Post subject: Reply with quote
Forget e-bay unless you know specifically what you're after.
Pirtek (Yellow pages) do very nice hose, it's vaguely flexible but not much.
Gates, available from proper automotive places and Halfrauds and do a very nice flexi hose, 600mmlengths IIRC
Try the best you can to keep the original I/D of the hose. A 32 -> 28mm2 is a severe reduction in Cross Sectional Area
Now, Pirtek is rubber hose so therefore a very good insulator. Going metal is going to dissipate the heat soooo much better.
If you go copper, insulate the copper from the chassis with plastic coated clips - galvanic corrosion might set in (Google or dogpile's your friend here - make your own mind up). Insulate the copper from your block using rubber pipe too, copper & ally/steel isn't a good idea.
I'm running NA Scooby, 4m pirtek, chassis rail mounted XJ40 rad with no worries
ruby bay
PostPosted: Thu Apr 02, 2009 11:59 pm    Post subject: Reply with quote
i looked at copper piping but couldnt find anything over 28mm, am i looking in the wrong places? if i go rubber i would prefer one continious length for the hole bus, i really dont fancy the expense of all those hose joiners and possible leak spots. cheers, mike
ricola
PostPosted: Fri Apr 03, 2009 9:12 am    Post subject: Reply with quote
For anything bigger than 28mm copper you have to go to a decent plumbers merchant, don't expect to get it in your average DIY store...
http://www.ricola.co.uk
ruby bay
PostPosted: Fri Apr 03, 2009 10:29 am    Post subject: Reply with quote
thanks ricola.
PostPosted: Fri Apr 03, 2009 1:31 pm    Post subject: Reply with quote
Pirtek is available in any length Happy
Bigbadbugga
PostPosted: Fri Apr 03, 2009 3:17 pm    Post subject: Reply with quote
car builder solurions is where I shop for the bits you can't get anywhere else.
http://www.cbsonline.co.uk/hoses-11-c.asp
ruby bay
PostPosted: Fri Apr 03, 2009 8:29 pm    Post subject: Reply with quote
cheers chaps. some food for thought there. thanks.
ruby bay
PostPosted: Thu May 21, 2009 11:49 am    Post subject: Reply with quote
hi all, does anyone have any experience or knowledge regarding the cappiliar thermostat switches? i am looking at buying a 12"fan with the adjustable temp switch. apparently they can either be fitted to the fins of the rad or put into the top hose. if you pop them into the hose, do you still get a good seal? is sticking it to the rad going to get an accurate water temp reading, especially when on the move with air flow etc. cheers, mike.
Rogbik
PostPosted: Fri May 22, 2009 10:06 pm    Post subject: One of these? Reply with quote
I used one of these...
http://www.cbsonline.co.uk/adjustable-fan-controller-thermostat-stat-763-p.asp
from Car builder solutions, figured it would be best as as I was unsure how well the Rad set up I've got (under floor/ beetween chassis rails) was going to work, fed the pick up into the 'top' radiator hose, used ptfe tape and a smear of red hermatite to ensure a good seal and it seems to have worked ok, the only thing I found is that the wire that runs from the sensor to the control unit is a fixed length (it cannot be altered) so the only place I could mount the control unit was under the drivers seat with the adjusting dial exiting just under the bottom mount for the drivers side seat belt (hope that makes sense! this is in a Bay by the way)
Rogbik
PostPosted: Fri May 22, 2009 10:11 pm    Post subject: Reply with quote
By the way, for my long run water pipes I used 32mm ID thick wall alloy tube from metals 4 u.
Not bad prices and excellent delivery times but make sure 100% that you know what you want and double check your basket before you order cos there's no going back once you hit the checkout button!!!
ruby bay
PostPosted: Sat May 23, 2009 9:54 am    Post subject: Reply with quote
thats just what i was looking at! many thanks for the links mate. mike.
