ping Jedi Master
Posted: Mon May 20, 2013 6:34 am Post subject: Cooling pipes with rolled ends? |
I'm redoing my water pipes as I have just used straight ally pipe (38mm) and my silicone joints keep migrating down the pipes even with 2 jubilee clips on!
My question is where can I get new pipes made in either ally or stainless with the rolled bumps on the ends to prevent the joints sliding off? Mail order? |
ricola Jedi Master
Posted: Tue May 21, 2013 9:55 pm Post subject: |
try doing some DIY beads, some good how to's about with modified mole grips to great the bead.. _________________ http://www.ricola.co.uk |
ping Jedi Master
Posted: Wed May 22, 2013 6:31 am Post subject: |
| I've started to make a bead roller jig in the mean time! I've also found a company called auto silicone hoses that do short bits. |
mackaymanx Initiate Jedi
Joined: 28 Oct 2011 Posts: 25 Location: Queensland,Australia
Posted: Wed May 22, 2013 10:27 am Post subject: |
Here is one is one I made from a scissor jack and some test pieces.
ping Jedi Master
Posted: Wed May 22, 2013 12:22 pm Post subject: |
| Nice, any more details on the jack roller. The beads look really good, what did you use as formers? |
Superleggo Jedi Master
Posted: Wed May 22, 2013 8:22 pm Post subject: |
Class effort. Have you any more pictures of the jack as I would love to make one.
Great solution |
Posted: Thu May 23, 2013 8:07 am Post subject: |
Ok I have to admit I can't find it at the moment as I'm in the middle of some reorganising. I'll try to find it tomorrow and get some more pics.
It was a standard scissor jack(VS Commodore) which had been damaged. The shafts are from alternators, as are the bearings and the spacers between them. The forming roller is just another spacer which was let spin on the shaft as I ground it to profile(watch you fingers it get hot while you profile it). The ring which holds the former on is from a beetle generator, it has an interference fit on the shaft. |
Posted: Tue Jul 16, 2013 11:09 am Post subject: |
splitbusvanatic Jedi Master
Posted: Tue Jul 16, 2013 12:05 pm Post subject: |
| That's cool. |
