you built oil sump
hansend23
PostPosted: Thu Mar 05, 2009 6:36 pm    Post subject: you built oil sump Reply with quote
this is my frist post,im wondering if anyboby is building there own oil sumps
for what ever engine you run.i built one for my 91 ej22. ive got the harness and adaptor ready.all i have now is cooling and exhaust.
is there a place for oil sump posts? ill keep checking.this is the website ive been looking for.i had many questions and they are now answered.its a nice place.
just do it!
PostPosted: Thu Mar 05, 2009 8:17 pm    Post subject: Reply with quote
Yep, a couple different. I will mould a new one for my bus EJ20.
hansend23
PostPosted: Sat Mar 07, 2009 4:59 pm    Post subject: Reply with quote
are there any oil sump ideas on here?ive almost searched everything,thankx.Clay,who used to work with me,is doing his conversion here too now.he has a 66 bug and using a 91 ej22 also.and needs clearence from the road Happy
just do it!
hansend23
PostPosted: Thu Mar 26, 2009 6:38 pm    Post subject: Reply with quote
heres a not so good picture of mine.i copied the KEP design from
picts.ill add more out the other side later.
just do it!
PostPosted: Fri Mar 27, 2009 10:05 am    Post subject: Reply with quote
http://www.blabberon.com/oilpan.html
http://www.brick-yard.co.uk/forum/subaru-install-live-part-1_topic27684_post206267.html
http://www.outfrontmotorsports.com/oil_pan.htm
http://burleysmotorsports.com/zencart/index.php?main_page=product_info&products_id=2
Here is what I will do:
http://www.optionimports.com/oilpans.html
And here, a performance version with a baffle plate:
MostlyMonki
PostPosted: Fri Mar 27, 2009 10:47 am    Post subject: Reply with quote
search for "oil sump", we dont tend to call them pans over here Happy
'72 Ratty Bug - Subaru EJ20 Turbo motor.
hansend23
PostPosted: Sat Mar 28, 2009 5:47 am    Post subject: Reply with quote
made the appropriate changes Wink Wink
just do it!
easy-does-it
PostPosted: Sun Apr 12, 2009 5:28 pm    Post subject: Reply with quote
I know it's my own fault for not checking before i started , but does anyone know the distance between the oil pump pick up pipe and the sump????..
Ive cut my sump down and cut the pick up pipe giving a ten mm clearance and just want to see if this will be ok...
'76 bay going superfly TDI
hansend23
PostPosted: Mon Apr 13, 2009 3:31 pm    Post subject: Reply with quote
when i did my research i remember13mm.but ive seen closer.
and some weld a rod across the bottem so if it gets crushed,it will
still pick up oil.across the pickup screen.
just do it!
easy-does-it
PostPosted: Mon Apr 13, 2009 7:50 pm    Post subject: Reply with quote
Cheers dude, i feel happier now Grin
