Glow Plug relay wiring
72panelvan
PostPosted: Sat Feb 21, 2009 4:58 pm    Post subject: Glow Plug relay wiring Reply with quote
Hi,
I've just found this glow plug relay pic on another forum.
Am I right in thinking that pin 50, by going to the starter solenoid, effectively acts as going to the ignition switch? I'm fairly clueless on wiring and just trying to keep wiring running up and down the van to a minimum.
Tom
PostPosted: Sun Feb 22, 2009 7:29 pm    Post subject: Reply with quote
Wouldn't the wire on the starter only be live when the ignition is turned right round (ie when starting)
Def sounds like it should be the ignition feed one though.
72panelvan
PostPosted: Sun Feb 22, 2009 8:13 pm    Post subject: Reply with quote
Cheers JP,
Decided to use the ford glow plug relay, checked the wiring diagram and like you said it goes to the ignition. Not too bad. The VW golf relay has all the wiring going through the bulkhead to the fusebox. Seems like a waste of wiring, so just going to use the ford one which is remote in the engine bay.
thought this link might be useful to someone, looks like a cheap, simple and fault finding friendly solution.
http://vincewaldon.com/index.php?option=com_content&task=view&id=30&Itemid=28
cheers
tom
