autohausdolby Padawan
Posted: Tue Aug 08, 2006 10:25 am Post subject: Turbo motor to NA flywheel? |
Am I right in thinking that a turbo engine can be fitted to a normally aspirated bell housing/clutch mechanism if the NA flywheel and clutch are used? _________________ www.autohausdolby.co.uk
VWSP85 |
doppelganger Jedi Guardian
Posted: Tue Aug 08, 2006 5:33 pm Post subject: |
yep and vise virsa like richard has ,2.5 non turbo to turbo clutch and flywheel  _________________ vwdrc class rep
Posted: Thu Aug 10, 2006 8:31 am Post subject: |
Cool, I'll have the cheaper bell housing then  _________________ www.autohausdolby.co.uk
VWSP85 |
Posted: Thu Aug 10, 2006 8:34 am Post subject: |
| autohausdolby wrote: | Cool, I'll have the cheaper bell housing then  |
it can still be upgraded later its on the slave cylinder that the differences are and the cross shaft ,there is no difference in the bell housing itself  _________________ vwdrc class rep
Posted: Thu Aug 10, 2006 8:41 am Post subject: |
Winner! I can't wait to not have to listen to the "crazy old women knitting at light speed" noice that the tappets make on my van  _________________ www.autohausdolby.co.uk
VWSP85 |
Posted: Thu Aug 10, 2006 4:25 pm Post subject: |
i`ve been thinking if you go for the cheaper bellhousing then add on a 2.2 flywheel and a 2.2 clutch it will come to more than getting the turbo one.you then have to buy no clutch if you have a manual one and the friction plate from your bus ,it will work out cheaper  _________________ vwdrc class rep
Posted: Fri Aug 11, 2006 8:41 am Post subject: |
Fair dos, I'm just a bit tight, that's all  _________________ www.autohausdolby.co.uk
VWSP85 |
