My conversion Pt II
PostPosted: Tue Aug 08, 2006 2:32 pm    Post subject: My conversion Pt II Reply with quote
Okey dokey I forgot some pictures & there's been a bit more progress.
While I was fiddling with the engine I checked the manifold/gasket/head fits. The gasket to the head was (thankfully) a good match. However the manifold to gasket left summat to be desired.....
So it was a nice sunny evening, out came the die-grinder & a scribe. I settled down in my camping chair for a while....
I did clean it up a bit more later. My excuse? Better fuel ecconomy Wink
Missed out this image in my previous post. It's the Custom Off Road throttle body inverter connected up to the inlet manifold
Right here's the dreaded reversed manifold clearence issue. The manifold has been moved approx 30mm back from it's proper seating pos'n.
Grrrr, FSWB and all that.
Still, there's a reason I've now found the clearence problem. The manifold is sitting on the engine in the above shots.
It's not up and running yet. I decided to remake my support hanger to allow more clearence for the exhaust etc. Still have to fab the rad mount but I now have the bobbins & also the temp exhaust system.
It's a hell of a job when time is short.
I hope you're enjoying reading these posts
PostPosted: Tue Aug 08, 2006 4:14 pm    Post subject: Reply with quote
good progress....will this be the first fully documented conversion thats actually going to be completed on VWKD I wonder
will it be finished by and are you going to van fest BTW?
ricola
PostPosted: Tue Aug 08, 2006 5:30 pm    Post subject: Reply with quote
Can't you just cut a V out of the coolant pipe and reweld it pointing downwards? You already have the bleed pipe at the top so trapping air shouldn't be a problem..
Rich
doppelganger
PostPosted: Tue Aug 08, 2006 5:35 pm    Post subject: Reply with quote
Rich
thats what i would do as well ^^^^^^^^^^^^^^^^^ Grin
vwdrc class rep
PostPosted: Tue Aug 08, 2006 10:23 pm    Post subject: Reply with quote
Rich
Wood, trees, trees, wood. Ummm might just do that! My head's been hurting loads thinking about this (you know how it goes). Almost as much as cracking it on the floor after nosebutting the chassis rail.
Cheers guys, will seriously consider this tomorrow. Will have to move the heater return line. I went to a scrappy last Fri and bought another!
I have tomorow off so I might just make it to the guy who does TIG. Hope to finish the support bar all barr drilling the chassis & do the rad mount.
Tonight's progress almost saw the engine support bar finished Grin
Had to rescue a Dragon Fly from the garage too. Neighbor couldn't believe it was sitting on my hand - wish I'd got a camera at the time.
PostPosted: Tue Aug 08, 2006 10:27 pm    Post subject: Reply with quote
[whispers] I bloody hope so. [crosses fingers]
If we make it there you'll be totally larruped on free beer
