hansend23 Jedi Master
Joined: 04 Mar 2009 Posts: 333 Location: Washington state
Posted: Sun Aug 16, 2009 11:42 pm Post subject: homemade vss |
this is my homemade vss.its an EGR light mileage counter box.that turns the light on every 15,000 miles.i dont know if you have thhese where you are,not all cars had them here too.
so its the reed sw from the scooby speedo,a magnet block from a pertronix electrik ignition. the two ends of speedo cables welded together
and some brass square stock filled with solder for the short cable.
 _________________ just do it! |
claw_finger Force Sensitive
Joined: 21 Oct 2007 Posts: 12 Location: deaf, dumb & blind
Posted: Sat Aug 22, 2009 8:13 am Post subject: |
dude, for us dumb out there, what's a vss  |
Posted: Sat Aug 22, 2009 2:59 pm Post subject: |
Vehicle Speed Sensor
It normally gives 4 pulses per wheel revolution to the ECU. Some Scooby lumps require it or the ECU throws a wobbly. _________________ The advice you receive on here is worth the paper it's written on.
Smoothlookinbay Padawan
Posted: Wed Sep 09, 2009 5:13 pm Post subject: |
I dont really know what the "EGR light mileage counter box" is?
Also, could you use a crank sensor as a speed sensor? Or the speed sensor from a different car? _________________ It WILL be ready for the summer, just like it was going to be ready for last summer. And the one before that... |
Posted: Thu Sep 10, 2009 10:19 am Post subject: |
here in the us vehicles have a egr timmer set to trigger the light on every 15000 miles as a mantainance reminder.
i think other vss would work.if they count 4 pulses every rev.
rjes has a good one ,very simple. _________________ just do it! |
