1800D into T25 pick up
crossbred will
PostPosted: Sun Dec 23, 2007 12:32 am    Post subject: 1800D into T25 pick up Reply with quote
Got a bit further with it today. The box is all back together, you can see the conversion plate on and the thrust bareing exention (will be shorter than that but made it longer so easyer to mark out) Grin
Got the engine in and worked out how to work the mounts so they dont foul the xzorst and water pipes
The easest way to get the xzorst out is side exit but im not sure how the law stands for side exit on the n/s?
Pleased with the progress todat its just a shame that its got to come out again as i cant get a clutch plate till mon Sad
PostPosted: Tue Dec 25, 2007 7:00 pm    Post subject: Reply with quote
Good work fella you'll put, put, putting along in no time!
crossbred will
PostPosted: Wed Dec 26, 2007 9:22 am    Post subject: Reply with quote
Got the first engine mount finished on mon,
Bit brutal but i am a agri engineer Laugh Out Loud
Cant do the other side mount till starter turns up (hopfully tommorrow) so yesterday a gave the front end a tickle with my lowering stick Grin
Before:
After:
Not a bad drop would like to go more but havnt got and shorter schocks yet, another 1.5 inch would just bury the top of the tyres in to the arch but im not sure if i will manage it yet due to thse wheels being a little large - 225/45/17 all round
crossbred will
PostPosted: Thu Dec 27, 2007 1:45 am    Post subject: Reply with quote
Didnt look right so ive taken it down another inch on the front, now just shy of a 4" drop Grin like the rake but the back might have to come down a bit
crossbred will
PostPosted: Sun Mar 23, 2008 8:29 am    Post subject: Reply with quote
sorry ive not put any thing up for a while, ive not had time to get back to my truck.
I ended up with a fiat clutch plate in the ford flywheel and spring plate turns out i put the input shaft from my fiat twin cam conversion in (yes im a tit! but can use ford clutch with that so no worries!)
After getting the engine in it turned out to have 2 stuck valves so its out again. I brought a td escort for less than a new head gasket for the non turbo Grin Thats now in and almost finnished.
I ended up taking a hole saw to the bottom of the bell housing so i could measure the thrust baring up properly, looks like this now:
Just got water pipes, exzorst and wiring to finnish that should be done today and fire up 2 morrow Grin
Will let you no how i do Hello
i may be lost but im making dam good time!
PostPosted: Sun Mar 23, 2008 2:48 pm    Post subject: Reply with quote
Good stuff TD is the way forward Grin
Be interesting to see how you find it as this is what I'm putting in my bus.
One thing I recommend is do as per the first couple of posts on this thread if you get a chance really perks up the engine... I did it on my Mondeo TD a month ago and it goes soooo much better.
Good luck and keep us posted.
crossbred will
PostPosted: Sun Mar 23, 2008 7:00 pm    Post subject: Reply with quote
Just had a look at that, makes a lot of sence. çheers for the link Wink
crossbred will
PostPosted: Mon Mar 31, 2008 9:10 pm    Post subject: Reply with quote
got it up and running on sat pm, its first run out was 100 mile towing a mk1 passat Eeeek All went well apart from a couple of bits, the minor one is the diesel is draining back to the tank when its stood so it needs bleeding every morning, got a one way primer from a pug coming to solve that Grin
The other prob was a little more serious, the turbo melted the clutch slave cylinder that was a interesting drive home Laugh Out Loud
I havnt measured it properly yet but it seems to be averaging 30 mpg (ish)
Looks like this now, almost finnished
What do you all think?
PostPosted: Mon Mar 31, 2008 10:53 pm    Post subject: Reply with quote
looks cool - like the matt black look! i can forsee i will have similar turbo heat sink issues on my subaru turbo as its right next to the slave. I was hoping some ali plating should help shield it a bit...be interested to see how you solve it. I think Agriemach do some decent looking heat management products - although i was probably going to go home made.
Good work though...im sure JP will be wanting some wiring tips Wink
PostPosted: Tue Apr 01, 2008 3:06 pm    Post subject: Reply with quote
Good work fella. I have a non turbo 1.8d and would love to swop to td at some point so any info on the turbo conversion etc would be great. Is there any differance as the mturbo is mechanical? The van is looking great btw
72panelvan
PostPosted: Tue Apr 01, 2008 6:15 pm    Post subject: Reply with quote
that looks shite hot! hat's off to ya! don't sierra turbo manifolds mount differently? As they are longitudinal?
Tom
crossbred will
PostPosted: Wed Apr 02, 2008 8:25 pm    Post subject: Reply with quote
cheers for the surport, going to use a bit of ali checker plate to shield slave, glad you all like the truck, its off to be flamed soon Grin
As for the wiring, dont ask me, my heater plugs are wired direct to a 240v light switch and ive pulled a ignition live from the coil to the fuel shut off solaniod, thats as good as it gets, im colour blind Laugh Out Loud
