spock Initiate Jedi
Posted: Fri Apr 28, 2006 10:39 pm Post subject: fuel |
what have you done on fuel pump in tank job was thinking of fucked up tank then cut guts out then put them in my imp tank  |
Posted: Mon May 01, 2006 10:10 pm Post subject: |
im going in tank pump but its all in progress at the mo - im trying to find out if the pressure relief valves are ciritcal to operation at the mo?? any ideas?. Turbo and I guess normall aspirated are the same have fuel tank like saddle bags - either side the prop. So they have 2 senders -so im keeping original VW sneder but using the scoob pump and swril pot cos its cheap  |
rjes Jedi Guardian
Posted: Sat Jul 29, 2006 3:43 am Post subject: |
Hello Rich,
Have you sussed out how thre Subaru system uses a venturi in the return pipe to suck fuel from the non pump side into the container inside the tank which surrounds the pump? Very clever, but it took me ages to understand how it worked! _________________ Regards,
www.rjes.com |
ricola Jedi Master
Posted: Sat Jul 29, 2006 7:24 pm Post subject: |
I was wondering what that all that plumbing did! Do you know if I have to keep both of the senders to use the Subaru instruments Rich? Some way of tricking it and using one?
Cheers, Rich _________________ http://www.ricola.co.uk |
