ford 2.8 V6 in a T25 panel - whats involved/needed
Jonnyg
PostPosted: Thu Sep 18, 2008 8:29 am    Post subject: ford 2.8 V6 in a T25 panel - whats involved/needed Reply with quote
basically what the title says...
My 1.9DG is on its last legs so its time for a new engine. I could rebuild but as i have the tools and the time i have decided to go for an engine swap...
2 engines have stuck in my mind, the rover V8 or the ford 2.8 V6 so i am offering each up to see whats going to be better.
I know i will need an adaptor plate to fit and i will need to custom make some mounts but what else is involved?
Does the engine sit proud of the hatch?
Will the gearbox be OK with the power increase?
And basically is it a pain in the arse or easy enough?
ruby bay
PostPosted: Fri Sep 19, 2008 10:12 am    Post subject: Reply with quote
the 2.9 engine should be easier as it uses an ecu, far easier to wire in than the 2.8i as the fuel metering gubbins can be a pain apparently. look at www.t2customs.co.uk , theres a 2.8 bay on there if you want an idea of fit sizes etc.
i am looking at putting a pinto or 2.9 in my bus over winter too.
PostPosted: Mon Sep 22, 2008 11:19 am    Post subject: Reply with quote
Have you seen this http://search.ebay.co.uk/search/search.dll?from=R40&satitle=220240386215
ruby bay
PostPosted: Mon Sep 22, 2008 3:00 pm    Post subject: Reply with quote
ive got a pinto plate lined up now but £600 for the whole van and engine seems good value, youd get your outlay back after breaking the van up!
jerry79
PostPosted: Thu Oct 30, 2008 9:57 pm    Post subject: Reply with quote
2.8 hard to wire up???? well there are five wires for the ignition and then theres the starter motor???? sounds tricky!!!!!
79 twinslider bay 2.8 cologne v6
62 11window rhd split
02 passat tdi sport estate
86 1340mini
