pantswagen Padawan
Posted: Sat Nov 01, 2008 8:17 pm Post subject: hello please |
i have finally done some custom hubs for fitting porsche 996 brakes to a type 2
-they fit bay
the fit brasil king pin spindles
custom hubs, stock everything, one caliper adaptor
stock porker disc and caliper
use boxster 2.5/7
's' - 996
996 turbo
gt3 6 pots 350mm disc
bolt on
stock bearings - seal grease cap
widget, back plates
caliper bolts
spindle jam nuts
the hub has a porker spigot, so it can take oem spacers to let you widen the track
-hubs are now, 20mm narrower than stock bay
-use stock porker studs,
i have fattened the flange
ii need 25 customers to get you them at £200 a set
-plus the adapters, i havn't got a bulk price yet, but as they are a non handed item, they work left or right, they wont be too dear!!!
0774 858 2044 |
