02a tdi reduction gear starter to 091 diesel bell housing
PostPosted: Sun Aug 17, 2008 9:17 pm    Post subject: 02a tdi reduction gear starter to 091 diesel bell housing Reply with quote
i was looking for a way to run the shorter, thinner, lighter,easyier to find and most importantly cheaper vw golf tdi 02a starter motor on my bay camper i have fitted with the 091 t25 diesel bellhousing as i am limited to room above due to petrol tank shelf as i have set the gearbox at the original angle with the new tdi engine fitted.
here's what i came up with:
this is what i got back from the machine shop a adaptor plate to hold and centalise the smaller nose'ed golf starter
i then cut the outer shape and drilled, tapped & countersunk the mounting bolt holes as you can see here
this is the starter adaptor plate fitted to the bellhousing with countersunk bolts
starter motor fitted to adaptor plate/bellhousing
a picture showing the old and new starters side by side
i have got all the starter and flywheel bits now and will be refitting the 1.9 tdi engine to the van within the next few weeks and then i will be able to tell you if it all works ok
Bugsy_malone 666
PostPosted: Sun Aug 17, 2008 9:36 pm    Post subject: Reply with quote
well that looks pretty neat!
Couple of questions:
firstly how thick is the piece of aluminium you used?
how did you know this would be the right thickness?
What diameter hole did you have cut for the starter?
that way I can get my bits together so that soon as my motor arrives I can install also Happy
cheers for letting on another great secret to an engine conversion Happy
Second Gear All The Way Baby!
Doing Thing Differently.
PostPosted: Sun Aug 17, 2008 10:17 pm    Post subject: Reply with quote
no1: the plate is steel and is 15mm i belive i've had it about a monthso i'd check first before making one!
no2: i measured the starter pinion lenght from the mounting face to gear end on both starters and took the shorter measurement from the longer one and the difference is the thickness of the plate.
no3: i can't remember the exact measurement, i took the two starters too my man and told him too make the hole fit the starter.
when you've done the conversion tell me how it goes as i wont be using it for a while as i dont have a turbo or manifolds till vanfest or a wiring loom made and ecu sorted
Bugsy_malone 666
PostPosted: Sun Aug 17, 2008 10:59 pm    Post subject: Reply with quote
Ah the one I'm getting looks like the nose end is slightly shorter, I hope its got the right number of teeth? I see theres a few different types but hell lets see what works!
Bugsy_malone 666
PostPosted: Sun Nov 02, 2008 10:28 pm    Post subject: Reply with quote
ok well I have sort of tried mine out on the engine but havent checked it over properly, the thickness of aluminium I have used is 12.7mm (apparently as thats what I bought) It seemed to do the job ok, Mines slightly different in design and made at home with a holesaw but essentially based on that, I need to actually check through the little timing hole to see how much throw/clearance I get on the gear by disconnecting the motor cable and just activating the solinoid. the thing will be if it actually fits in the van!
