The oil filler tube came really high on my TDI. But why?
sven
PostPosted: Wed Jul 27, 2011 10:12 am    Post subject: The oil filler tube came really high on my TDI. But why? Reply with quote
Yesterday when I finally put the TDI engine in the van, the oil filler tube is much higher than before (as with the 1.6TD). I can't really understand why...
The engine mounts are the same, I have the 1.6TD oilpan, the engine position looks good and still the cap is above the hatch.
Anyone seen this before?
trev
PostPosted: Wed Jul 27, 2011 5:32 pm    Post subject: Reply with quote
different cap? different cam cover? From memory the 1.6TD uses an 8-bolt cam cover but the TDI uses a 3-bolt one. They might be different heights...
sven
PostPosted: Wed Jul 27, 2011 6:33 pm    Post subject: Reply with quote
The oil filler tube is mounted in the very bottom end corner of the sump... Happy
I'm not sure how it was before, and when talking to a friend he said that the Syncro has a different tube. I think the previous owner replaced the engine with one from a Syncro to get it running.
The bus also has an AAP gasoline gearbox and the diesel gearboxes have a much lower end mount, so that will for sure make another noticable difference.
Anyhow, I cut it and welded it where I wanted it to be. End of story. Happy
sven
PostPosted: Wed Jul 27, 2011 7:24 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=5472539
