ricola Jedi Master
Posted: Wed Aug 23, 2006 9:26 am Post subject: EJ20t Sti speedster |
I've had a bad influence on a friend at work
Currently getting into the engine fitting and I've got him to put up a picture diary:
http://apspeed.spaces.live.com/photos/
Highlights are:
speedster clinic speedster replica
NA 944 rear brakes
detailed 16" fuchs
will be black
1999 sti engine
DS tuning adapter plate
raised rear trans mount to raise sump
mid mount
AT trans
autohausdolby Padawan
Posted: Wed Aug 23, 2006 12:49 pm Post subject: |
That's cool! I don't normally like Speedster replicas, but that is going to be awesome  _________________ www.autohausdolby.co.uk
VWSP85 |
surfbeetle Force Sensitive
Posted: Thu Sep 21, 2006 3:21 am Post subject: |
| The photos are great. By the way, where did the speed sensor come from? I haven't seen one that works with a vw speedometer cable and I am very interested in getting one. Thank you. |
ricola Jedi Master
Posted: Thu Sep 21, 2006 7:53 am Post subject: |
We got it from subaruboxer who is in Germany (I think), apparently they are used a lot in taxis. They only give two pulses per rev opposed to the 4 that Subaru uses but it seems to work fine..
ricola Jedi Master
Posted: Mon May 19, 2008 7:53 am Post subject: |
Another interesting project Rich. I think your days must have more hours in them than mine do!
I stock a speedo cable VSS for the standard -->83 M18 x 1.5 VW speedo cable thread. See http://www.rjes.com/html/vss.html .
They are 4 pulse, fit the cable perfectly without mods (unlike some I tried), and work perfectly on a Subaru engine. I cab also get 8 pulse ones to order, if that's any use on other engines. _________________ Regards,
ricola Jedi Master
Posted: Mon May 19, 2008 6:45 pm Post subject: |
Cheers for the info Rich but we sourced a screw in pulse generator years ago, he is also using the 924 gauges so could have got the signal from that too! _________________ http://www.ricola.co.uk |
