did the worst thing ever last week i said to our floss ide got every thing to sort my conversion (ej22 early bay) apart from hoses.......me and my fecking big mouth since then ive had to source a 20mm clutch cross shaft wich came without arm so about a week later sorted.then i thought i would check my flywheel i sourced with the clutch ide bought feck me it didnt fit after 3hours of staring at a p.c screen turns out ive been sent a turbo one so being a smart arse rang scooby clinic to see if they would swap .no probs they said ,so fri afternoon off i podle takes me about an hour to get there turns out they avnt feckin got one so after all that i still have to send it back to grade a....i know these things are sent to test us
but gimme a feckin brake _________________ Sutton in Ashfield .Nottinghamshire
home of the robin hoodys
Posted: Mon Apr 21, 2008 7:45 pm Post subject:
It ain't just you fella. Wanna talk about steering pins on a bus
1/ Order parts that you know you're gonna need
2/ Wait 6 weeks before starting
3/ Use ball joint separator
4/ Eventually 'pursuade' bushes out (B'stard things, really in good un tight)
5/ Offer up new bushes - 1.5mm oversize
6/ Mate comes up trumps with phos bronze bushes - need reaming
7/ Coax new bushes in (no sign of friend with reamer)
8/ Clean up threads on ball joints
9/ Splitter's bent one thread, it's buggered.
10/ Will tell you when I do it. Grrr, got tomorrow off now! _________________ The advice you receive on here is worth the paper it's written on.
got to love them still.i cant belive i spend 16 years of my life tinkering with lawn mower engines then decide to go watercooled ....you cant beat a challenge _________________ Sutton in Ashfield .Nottinghamshire
Posted: Tue Apr 22, 2008 5:57 pm Post subject:
You're going to love the m/way cruising bud
Update
10/ Ream out bushes no probs
11/ Ordered Fixed track rod and new ball joints & steering idler pin (just in case) pop into town & pick them up
12/ Fit Fixed rod no probs
13/ Try to remove 'other' ball joint from adjustable bar (one already removed) - no hope, order new bar for del tomorrow
14/ Fit a ball joint to Y shaped bit on steering arm, fix fixed arm too
15/ Find someone's really sent me the wrong idler pin (it's for a split), use one from 11.
16/ Go to attach Y bit, thread's graunched on the clamp, needs chasing and I haven't got a M12x 1.5 tap.
Ohhh, bloody Bug's speedo cable went on way back home. FFS! (thankfully I have two cars)
Still she should steer nicely after & 'solid' phos bronze bushes are gonna last _________________ The advice you receive on here is worth the paper it's written on.
