People with Side shift T25 gearboxes..
Post new topic   Reply to topic     Forum Index -> Volks Power
Bugsy_malone 666
PostPosted: Fri Apr 04, 2008 11:00 pm    Post subject: People with Side shift T25 gearboxes.. Reply with quote
I was wondering if I could see how you have made you gear change linkages up?
pictures of how the linkages fit would be grand as although I have my own idea for a linkage Its nice to see what other people have that works.
My box is a diesel if it makes any difference?
Second Gear All The Way Baby!
Doing Thing Differently.
chuggaboom
PostPosted: Sun Apr 06, 2008 5:35 am    Post subject: Reply with quote
was thinking of doing this but considering i dont have the box yet thet might be difficult to do mock ups
i assume you mean putting a side shift in a bay or split to retain the origanal gear change
Bugsy_malone 666
PostPosted: Sun Apr 06, 2008 11:48 am    Post subject: Reply with quote
well I have a T25 Diesel gearbox, it has a side shifter and its going into a 72 baywindow, making brackets to fit the box is a piece of cake its getting the stock shift mechanism to work when the one on the box is about 4 inches further across and further back than a stock bay one.
hence why I wanted to see some pics of a stock linkage to work out how to make mine work
chuggaboom
PostPosted: Sun Apr 06, 2008 9:55 pm    Post subject: Reply with quote
one way is to use the entire t25 linkage
i dont want to do this
i would prefer if it correct inside
Bugsy_malone 666
PostPosted: Sun Apr 06, 2008 10:01 pm    Post subject: Reply with quote
I been trying to see how the shift rod fits on a T25, I'd consider using the hole linkage but i think it goes below the chassis rails and thats not what I want.
from what I have seen T25s all have the sideshift, im sure this cant be the case because the front mount has a cut out for what looks like a front entry linkage.
I am currently working on a linkage to use stock bay linkage with a side shift box.
chuggaboom
PostPosted: Sun Apr 06, 2008 10:04 pm    Post subject: Reply with quote
gear linkage under the chasis rails is the other aspect i wanted to avoid
two people on here caddy and ilzlee have both got t25 boxes in bays
but run a the 25 linkage and gear shift
if i find the right gear box i will be trying the same thing
illzlee
PostPosted: Mon Apr 07, 2008 11:15 am    Post subject: Reply with quote
as i've said before, if anyone wants to see how mine was done they are free to slide under my van whenever. I'll even be attending some shows after i hand in my dissertation which is due for hadn-in in 27 days, 23 hours and 45 minutes, 30 seconds
29 seconds
28 seconds
27 seconds
god i've lost interest in it...
back to the grind
Bugsy_malone 666
PostPosted: Mon Apr 07, 2008 11:44 am    Post subject: Reply with quote
wouldnt it be easier to jsut post some pictures for us :P Happy
Bugsy_malone 666
PostPosted: Mon Apr 07, 2008 11:54 am    Post subject: Reply with quote
Just seen what you posted on kamperchat now Laugh Out Loud exactly what i needed to see to understand how it worked Happy
thanks muchly Happy
illzlee
PostPosted: Wed Apr 09, 2008 11:03 am    Post subject: Reply with quote
out of interest, why are you and chugga wanting to avoid the exposed linkage underneath?
is there someting i should know?
Bugsy_malone 666
PostPosted: Wed Apr 09, 2008 11:06 am    Post subject: Reply with quote
Well my bus is a tad low at the front and going round norfolk I managed to bottom out the suspension and even some of the beam/antiroll bar a fair amount, last thing I want is anything lower than the chassis rails hanging down!
Also having rads between the rails and scoop under it may cause interferance problems.
illzlee
PostPosted: Wed Apr 09, 2008 4:08 pm    Post subject: Reply with quote
ah i see. my van was low till i had to put phat tyres on it to increase the gearing. i too have a rad between the chassis rails and linkage doesn't foul it...
Post new topic   Reply to topic     Forum Index -> Volks Power All times are GMT
