beetleseb Jedi Knight
Posted: Sun Feb 24, 2008 10:47 am Post subject: subaru bits for a conversion |
Hi guys
Selling off some subaru adaptor bits
Wiring loom with ECU and manifold for a 2.2. You don't need to get the loom, cut it (huge job) and you know this one works (its still in the car) Its done by a pro (not me). The manifold also has all the bits you don't need taken off/blocked etc and has the throttlebody reverser thingy.I'll go through it with you so that you get the cold start etc right. £200
DS tuning adaptor for any EJ subaru engine (all legacy and impreza)(same as TSR apparently) 200mm clutch. Its been machined to take a vw t25 bearing to stop the clutch problems you can get with these and so the only disadvantage would be the vw starters a bit weak but it always started for me. £200
Custom Stainless Exhaust. Using RJES custom stainless manifolds and pro welded custom stainless tube. Uses a Jetex 2" backbox so easy to replace, looks perfect on a bay but should suit most, complete with lamba sensor etc. Cost me £450 to put together! £250
Any questions just let me know
Could post the exhaust and adaptor but the wiring etc would be better if picked up as its best to go through it.
Its all still in the van at the mo (bottem ends gone )but I'll take it out next weekend, so if your quick I'll take you for a spin.
Seb _________________ Everybody is someone else's weirdo |
lowlight 185 Padawan
Posted: Sun Feb 24, 2008 11:40 am Post subject: |
hi mate you got pm _________________ Sutton in Ashfield .Nottinghamshire
home of the robin hoodys |
Posted: Sun Feb 24, 2008 11:48 am Post subject: |
You have first refusal on the wiring and exhaust
Now who wants an adaptor?
Posted: Sun Feb 24, 2008 12:38 pm Post subject: |
wedgedout Force Sensitive
Posted: Thu Mar 20, 2008 4:02 pm Post subject: |
| did you sell the exhaust? |
