ed72bay Padawan
Posted: Sat Sep 15, 2007 3:12 pm Post subject: Best way to fit glass back in? |
Just smashed a side window so thought id ask if anyone knows a good way of fitting glass back in a bus?
cheers |
pepper Jedi Knight
Posted: Sat Sep 15, 2007 10:01 pm Post subject: |
Its very easy!! get some cheap washing line Asda Cheapo is usual.
fit it all round the seal overlapping the ends in the seal at the top then get a friend to hold window in aperture then start pulling the line round the window seal.
it all should pop back in takes about 10 minutes. |
pepper Jedi Knight
ed72bay Padawan
Posted: Sun Sep 16, 2007 8:05 am Post subject: |
cheers Pepper, my neighbour came up with the same idea too. Got three in without any further incident . They where very tight, twenty minutes each ! two to go, never again.
definately a two people job |
Posted: Tue Sep 18, 2007 11:21 am Post subject: |
Also worth noting if doing a windscreen start at the top with your washing line and work down, me and Rich had several failed attempts starting at the bottom which you would logically think to be the easier way.
 _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
2013 Scirocco TDI GT |
pepper Jedi Knight
Posted: Tue Sep 18, 2007 6:29 pm Post subject: |
| Ah I could have also told you that if I'd thought about it. |
Posted: Tue Sep 18, 2007 8:56 pm Post subject: |
You can loop at the top & one at the bottom, even easier. _________________ The advice you receive on here is worth the paper it's written on.
