toadheaddesigns Padawan
Posted: Sat Sep 15, 2007 4:32 pm Post subject: how straightforward is it to fit bus box into a bug (scooby) |
thinking that when the alfa wizard is done i might so a suby bug
i know of a low mileage legacy lump local to me N/A
i will be looking to either go for a 1303 chassis or irs a swing axle one
so how straight forward is it and is there a how to guide. Also which bus boxes should i keep a look out for. I would be thinking of going down the rjes bellhousing route, so would a flywheel adaptor like the one from ds tuning still be required? _________________ "Doc I can't stop singing The Green, Green Grass of home"
"That sounds like Tom Jones syndrome."
"Is it common?"
"It's not unusual." |
Posted: Sun Sep 16, 2007 5:33 pm Post subject: Re: how straightforward is it to fit bus box into a bug (sco |
| toadheaddesigns wrote: | | I would be thinking of going down the rjes bellhousing route, so would a flywheel adaptor like the one from ds tuning still be required? |
Nope, RJs bit takes care of it for you:
Standard manual Scooby flywheel, pressure plate, starter and release bearing.
Standard Type 4 (pancake) friction plate. _________________ The advice you receive on here is worth the paper it's written on.
doppelganger Jedi Guardian
Posted: Sun Sep 16, 2007 7:20 pm Post subject: |
ive done all the above in mine,but im sure ricola will be along as well  _________________ vwdrc class rep
ricola Jedi Master
Posted: Sun Sep 16, 2007 9:19 pm Post subject: |
| doppelganger wrote: | ive done all the above in mine,but im sure ricola will be along as well  |
lol, bus boxes definitely have their place! just depends what you want to use the car for and I use mine 99% on the road and regularly so the short ratios would get to me
It would be a good excuse to use one of Rich's lovely kits though.. _________________ http://www.ricola.co.uk |
Posted: Sun Sep 16, 2007 9:22 pm Post subject: |
a quick question , can the ratios be changed and im only the first of many i think who are gonna go the rjes busbox route  _________________ vwdrc class rep
split_trix Jedi Knight
Posted: Tue Sep 18, 2007 12:49 pm Post subject: |
Hi, i'm currently doing a bus box and vwrx conversion on my split bug, bugger and bugger again forgot about it needing a type4 friction plate.... where can u get discs cabale of 300bhp ?
btw anyone want a subaru clutch disc capable of 340bhp bought from techniclutch?
help... as nearing engine and gearbox mating.. BUGGER
chris
as for changing the ratio's i've looked into this... the places over here that can do it is the usual one COGBOX or BEARS... but if you wanted to do yourself then LONGENTERPRISES are you people.. one thing i've found on the US OFFROAD forums is that the 3rd and 4th are fine teeth which need to be changed for course and the selecting of changed gear ratios may become more difficult _________________ 52 vwrx |
Posted: Tue Sep 18, 2007 4:05 pm Post subject: |
im using a porsche 911 2.2ltr clutch  _________________ vwdrc class rep
Posted: Tue Sep 18, 2007 4:12 pm Post subject: |
I assume its right diameter (228mm) right spline etc etc.... are there any other porsche ones that fit... ? just had an email from rich from rjes and he said omp do an uprated vauxhall one that fits also but hasnt been proven in practice.....
cheers
chris _________________ 52 vwrx |
Posted: Tue Sep 18, 2007 4:24 pm Post subject: |
| split_trix wrote: | I assume its right diameter (228mm) right spline etc etc.... are there any other porsche ones that fit... ? just had an email from rich from rjes and he said omp do an uprated vauxhall one that fits also but hasnt been proven in practice.....
cheers
chris |
read the times in my sig _________________ vwdrc class rep
Posted: Tue Sep 18, 2007 4:25 pm Post subject: |
where do u get it from and how much did it cost ?
Posted: Tue Sep 18, 2007 4:26 pm Post subject: |
| split_trix wrote: | where do u get it from and how much did it cost ?
chris |
i will enquire more cos mine was second hand  _________________ vwdrc class rep
rjes Jedi Guardian
Posted: Wed Oct 17, 2007 12:56 am Post subject: |
Hello Toadheaddesigns,
As you're in Stoke and I'm in Cheadle (sorry - not sure whether I know you), come and see me if you need any info if you like. My EJ25 Syncro is up and running again if you want a look / ride in it. Thanks, _________________ Regards,
www.rjes.com |
