split_trix Jedi Knight
Posted: Fri Nov 16, 2007 8:42 pm Post subject: megasquirt ecu |
Does anyone know if people have been able to use the scooby crank/cam trigger system with megasquirt ?
I've looked on www.msextra.com but the search page doesnt work..
chris _________________ 52 vwrx |
sven Jedi Guardian
sven Jedi Guardian
sven Jedi Guardian
Posted: Fri Nov 16, 2007 9:10 pm Post subject: |
MS2-Extra can also control the following cam/crank signals directly:
# GM HEI, GMDIS
# VW / GM / BMW / Bosch 60-2 crank
# Ford TFI
# Ford EDIS
# Toothed wheel decoder (e.g. Ford 36-1 Vauxhall 60-2, BMW 60-2, 12-1, etc.)
# Dual Wheel
# Nippondenso CAS
# LS1 Trigger
# Neon/420A
# Next Gen Neon (36-2+2 trigger signal)
# Subaru - RX8 (36-2-2-2 trigger signal)
# 99-00 Miata
# Mitsubushi DOHC 6cy (6G72)
# IAW Weber-Marelli (Cosworth)
# Subaru (6/7 trigger signal)
# Rover / TVR V8 3.5L - 5.5L (GEM's will need a 36-1 crank wheel adding) # Oddfire Distributor
# 4/1 CAS
# Mitsubishi 4G63
# Miata (4/2 CAS)
# Renault (Renix 44-2-2)
# Suzuki Swift Distributor
# Suzuki Vitara 2.0
# Ford Zetec, Duratec, etc, etc. (36-1 trigger) |
Posted: Fri Nov 16, 2007 9:37 pm Post subject: |
superb....... so i dont have to try and machine down an alloy crank pulley for a trigger wheel...
I'm surprised that megasquirt has moved forward so much since i last looked...
So it should beable to directly drive the coil packs ?
sven Jedi Guardian
Posted: Sat Nov 17, 2007 1:56 pm Post subject: |
| Yes. |
Posted: Sat Nov 17, 2007 4:34 pm Post subject: |
any coil pack, even MSD's ?
sven Jedi Guardian
Posted: Sat Nov 17, 2007 7:51 pm Post subject: |
| I believe so, I'm setting up my new engine with the original coils. |
Posted: Sat Nov 17, 2007 9:34 pm Post subject: |
I was thinking of MSD packs b4 i realised i had the orignal scooby ones still in the engine... so all is good....
Have yuou heard of the surface mounted chipped megasquirt i think v3.57. Do u think its that much better than the MSII V3 to warrant going for a built unit rather than home made ?
sven Jedi Guardian
Posted: Sun Nov 18, 2007 10:07 am Post subject: |
| Sure it's better with surface mounted electronics, but I haven't heard of any real problems with the home soldered cards. The biggest parts can be supported by a small shot with a glue gun and then they can take a lot of tough roads. I know people running DIY-MS cards in their rally cars, and if that's not bumpy so tell me... |
