Which fuel pump?
mark-s
PostPosted: Mon Mar 20, 2006 6:20 pm    Post subject: Which fuel pump? Reply with quote
I have a EJ18 from a 1991 Legacy, but don't know which fuel pump to use. Being a '91, it has a carb, not fuel injection, so I don't think a high pressure one would be appropriate. It still has a fuel return line & swirl pot like the later cars though.
Anyone got any ideas?
lister
PostPosted: Tue Mar 21, 2006 3:00 pm    Post subject: Reply with quote
Can you get the standard subaru one ?
mark-s
PostPosted: Tue Mar 21, 2006 5:24 pm    Post subject: Reply with quote
well i had the whole car, but stupidly i didn't take the fuel pump as it was in the tank.
spock
PostPosted: Fri Apr 28, 2006 10:45 pm    Post subject: Reply with quote
just go to scrappers and get one of a jap with carbs dosent matter about pressure as it will have a presure reg on it . did that on my 412 worked good .. sean
stcos85
PostPosted: Wed May 24, 2006 7:52 pm    Post subject: Reply with quote
I bought one off of a c class merc as it was external to go with my EJ22. Will this do the job?
PostPosted: Sat Jul 29, 2006 3:27 am    Post subject: Reply with quote
An EJ18 with a carb? That's interesting - never seen one of those before. I thought the entire EJ range all had multi point injection. Is it definitely and EJ18, not the earlier EA82? Thanks,
mark-s
PostPosted: Wed Aug 30, 2006 7:56 am    Post subject: Reply with quote
Hi Richard
Yes, it's definately an EJ18. In 1991, the UK subaru legacy came with a carbed 1.8 or EFI 2.2. I was lucky enough to get the official dealer repair manual for the car and this details the carburettored engine. It has a distributor attached to the LH camshaft & uses a Hitachi carb.
Hope that helps.
Mark
