converting t25 lawn mower box from nose-side, to nose shift.
MostlyMonki
PostPosted: Tue Aug 21, 2007 9:29 am    Post subject: converting t25 lawn mower box from nose-side, to nose shift. Reply with quote
I thought there was a thread on here already somewhere about converting an early t25 6 rib box to noseshift, but i cant seem to find it.
so....
Ive got a 6 rib box from an early lawn mower t25 (one of the ones with nosecone shift, but on the side of the nosecone), and i want to convert it so its basically the same as the 091 box with the proper nose shift.
what do i need? hows it done? etc. etc.
cheers,
Matt.
PostPosted: Tue Aug 21, 2007 11:44 am    Post subject: Reply with quote
Yer there was a thred quite resently about this, if I remember right all you need to do is swop the nose cone for an early T2 box. You'll obviously have to plum in the hydrolic clutch too.
MostlyMonki
PostPosted: Wed Aug 22, 2007 1:29 pm    Post subject: Reply with quote
would a nosecone from a 1.6 box be any use? and is there anything else i'd need?
PostPosted: Wed Aug 22, 2007 2:10 pm    Post subject: Reply with quote
Yes I'm pretty sure that would do it!
famous phil
PostPosted: Thu Aug 23, 2007 7:37 am    Post subject: Reply with quote
Hello you might also find that you'll have to change the sellecter bars inside the centre section of the box ,, thats what i found when trying to do this ''' but not sure if it was a bay 2.0L or 1.6L ,,,,, Happy
MostlyMonki
PostPosted: Thu Aug 23, 2007 10:13 am    Post subject: Reply with quote
did you manage to do it ok in the end Phil? was it much hassle?
famous phil
PostPosted: Sat Aug 25, 2007 10:18 pm    Post subject: Reply with quote
Sad no was a job i was helping my brother to do ,,, after he saw that the middle section of the box had to come to bits to change the linkage bars he gave up and put it all back together ,,, had a look today and it was a 1.6 bay box swap to 2.0 t25 ,, so i'll have to see if i've got a naf 2.0l baybox to do it with
