early bay resto
pepper
PostPosted: Mon Mar 26, 2007 9:41 pm    Post subject: Reply with quote
Its looking good I always prefer the lower light look to the later versions.
How are you going to remove that centre though?
chuggaboom
PostPosted: Mon Apr 02, 2007 3:14 pm    Post subject: Reply with quote
removing it at the mo pics to follow and
in answer to your question with dificulty and maybe a lot of filler hopfully not
famous phil
PostPosted: Tue Apr 03, 2007 6:40 am    Post subject: Reply with quote
Hello lower light for that cleaner look Cool
chugga whats the idea behind this tool in the drill
chuggaboom
PostPosted: Tue Apr 03, 2007 6:47 pm    Post subject: Reply with quote
the tool strips paint and underseal on flat surfaces very quickley it cost about 20 quid mind
and i only leaves a very light mark on the steal if used correctly you can see
it on the bulk head all light inperfections caused will dissapear with high build primer
its great i will ask my dad where he got it from
and now for an update
bump cut out
new plate tacked in
got it close dont you think
and a little distortion from the seam weld
but after a grind and a bit of a fettle it should all come true and very little filler will be needed all that on the next instalation of early bay reato Grin
chuggaboom
PostPosted: Thu Apr 05, 2007 7:37 pm    Post subject: Reply with quote
well a little done tonight
thats much better less filler needed now
and i have put some more rust preventer on the inside of the front panel a few more little repairs on it and i will be ready to lay some paint on it which will be exciting
oh i have also chosen my final colour you will have to guess what it is untill i show some pics with some top coat sprayed but knowing me that will be weeks
so get guessing
and ia little prep on the chassis leg before the new bit gets stiched in
Covin
PostPosted: Thu Apr 05, 2007 8:05 pm    Post subject: Reply with quote
Some very nice metalwork going on there m8
I've got my front panel to change over as well as it's currently the wrong one for the Bus with High indicators, job for winter time though as it'll do for now Grin
Keep the updates coming.... I'll have a guess at the colour Very pale light Green ? ? ?
DARREN
I LOVE RUST ME
famous phil
PostPosted: Thu Apr 05, 2007 8:24 pm    Post subject: Reply with quote
Hello doing a top job
colour was thinking the same as covin but then thought light blue try not to go for a dark colour as it shows every imperfection ,,,,
PostPosted: Thu Apr 05, 2007 10:46 pm    Post subject: Reply with quote
Great work..my guess is savannah beige
chuggaboom
PostPosted: Mon Apr 09, 2007 5:13 pm    Post subject: Reply with quote
benn a slow weekend weater was good but had a lot to do at work and i locked the keys in the garage and my dad with the spare set was working on his boat at fosdyke 70 miles away so i have have to wait for him to get back tomorrow
and you will need to keep guesing
look back at the post for a clue and for the shade you will find it in a news agents
its not that dark sort of medium shade i would say but i will have to wait and see when i start to spray the insdide of the newly finished panel but i'm taking advantage off the good weather when i can get insie that garge the worst part is a can see the keys through the window
PostPosted: Mon Apr 09, 2007 9:27 pm    Post subject: Reply with quote
Looking at your earllier posts... it must be Pink
Grin
chuggaboom
PostPosted: Tue Apr 24, 2007 7:35 pm    Post subject: Reply with quote
thats red oxide beleive it or not bloody flash on my camera
and the hot weather and that missus of mine has kept me busy
but back on it npow and the front panel mocked up
its very close fit
and the a posts are just about done a littlet triming and resahpping and that will be it
and very pleased with this weld much better than the chassis as you can see
chuggaboom
PostPosted: Wed May 09, 2007 8:53 pm    Post subject: Reply with quote
well i have been very busy at work
so all i have done is the the ineer font valance and mocked up for the new drivers side arch to do this removed the old one if you can call it that it was just a skin welded in and found that the b piller was a little rusty
that aside mocked up the arche for fit
need to hang my new door i got for 20 quid
and see how it all fits
and my dad went to the machine marts vat free day for some more gas for my mig and a few other consumables and he couldnt resist somthing he has wanted for ages
and cause its in the garage i can use it when ever i need
Page 5 of 6
