early bay resto
chuggaboom
PostPosted: Tue Feb 06, 2007 6:49 pm    Post subject: Reply with quote
i have a gargae as you can see from the other pics but its not as alrge as your the barns some of you have
in the garage it would be like covin and the other people that use the garage like my dad would be pissed off if the van was in there for months on end and end
plus I work on the railway so being outside isnt much of a change to what i do during the day and all the prep work folding and making of panels can be done in the garage
Covin
PostPosted: Tue Feb 06, 2007 8:37 pm    Post subject: Reply with quote
Is your garage a drive through one like mine ?
Mine is a good size and a drive through which is very usefull but it's no good for doing long term projects in as it means my Covin can no longer get out so it's trapped in the back graden until the Bus is done ...
Bit of a pain really which is why I'm going to build a new garage in the back garden for doing future builds in
DARREN
I LOVE RUST ME
chuggaboom
PostPosted: Thu Feb 08, 2007 6:21 pm    Post subject: Reply with quote
no its a double drve in and stay in work shop on one side so the door is blocked and the other has the pit in it the garage isnt really big enoughas the doors i think are the smallest you can buy
the bloke that built was a cheap skate if i ever get hold of my dads house i will extend it and have it so you drive in from the road its alot of work as its brick built
but i may do it as the rest of the house need barely any work
chuggaboom
PostPosted: Thu Mar 08, 2007 3:35 pm    Post subject: Reply with quote
oh well nothad internet for ages and been a bit busy with work its really annoying as well but work is coming on nicly
front panel is off and allmost all the rust is rubbed down a lot more chassis work to the front and i will be coasing in frosts rust preventor this is a water based rust preventor (dont ask me) which means i can over coat it on the zinga where new panels are in and then seam seal it athen under coat it and the front panel will be ready to go on
not geting that untill the weekend
going up to schofields open day
is anyone else going
chuggaboom
PostPosted: Wed Mar 14, 2007 10:57 am    Post subject: Reply with quote
i take it no body else went to the open day
was good great hospitallity got me a fairly decent set of early bay doors for 40 quid with opening quarter lights and glass
2 new arches
chassis repair piece for o/s the bit with all the holes
front panel
so all i need now is some cab floors and i will all teh panels i need for the b posts forward
starting to clean up the underseal and the paint on the inside and outside of the cab getting ready for some more rust killer and high build primer god its gonna look diferent removing all the other bits underneath so its a blank canvass for refitting incluing remote brake server and heater matrix but thats all to come
should have a computer running where i can upload pics as well for a proper update of my slow progress
chuggaboom
PostPosted: Thu Mar 22, 2007 10:42 pm    Post subject: Reply with quote
tim for an update with some photos dads comp working now with my camera so i can show you all what i havent been doing god women and work never stop distracting you
new a post on off side
too cold and wet so found some stuff do in the gargae engine lid bare metaled
and with the beam removed i found some more rust so i started to replace the rubish with new metal
and i started to cut out the other side to look at replacing the chassis leg when i have done with the other side did this as i ran out of gas and want to cut somthing
i relaxed a bit and removed the windsreen
and started to clean up the floor and arches in the cab
also mocked up the new chassis section for the extra bits i need to ad this now all fits and is waiting for better weather so i can weld out side
so in the mean time my front panel is now beeing modified to my own preferance
oh and the main thing that holds up this resto
chuggaboom
PostPosted: Thu Mar 22, 2007 10:55 pm    Post subject: Reply with quote
just a couple of pics here of front panel has been removed and the beam out
Covin
PostPosted: Thu Mar 22, 2007 11:14 pm    Post subject: Reply with quote
That brings back some bad memorys for me Grin
Good work m8, you'll get there, trust me. The front chassis is not to bad to do but the rear end is a nightmare to get into... Hope your rear chassis is ok
Keep the updates coming
DARREN
I LOVE RUST ME
PostPosted: Fri Mar 23, 2007 12:36 am    Post subject: Reply with quote
Good work matey doing a fine job roll on those warm light evenings.
I use axle stands to hold up my resto... never tried using a girl in a basque sounds like a plan though Grin
PostPosted: Fri Mar 23, 2007 11:22 am    Post subject: Reply with quote
Definatly looking forward to some long evenings-doing a great job fella
chuggaboom
PostPosted: Mon Mar 26, 2007 8:57 pm    Post subject: Reply with quote
well after a weekend of work and girlfriend and a late finish today not much has happened
remember this
well what you cant see is the distortion i got when welding it in its bowed inwards not good at all would need a lot of filler so my dad being the muti talented man he is has filed it with lead
leaving a lot less to fill with the normal 2 part body filler
i have also cut off the overlap where the the lower panel and upper panel fit to together for a smoother look
all i need to do now is remove the bump
i was thinking of preping and spraying the back of the panel before i put it in so it matches the final body colour
opinions and possible problems would be apreciated
thanks and another update soon
famous phil
PostPosted: Mon Mar 26, 2007 9:13 pm    Post subject: Reply with quote
Hello whatever you do dont stop m8 , your doing a hell of a job ,
Page 4 of 6
