Posted: Sun Nov 11, 2007 11:05 pm Post subject: |
bit more progress:
After a long hunt I found two t25 auto short driveshafts which will mean i dont require spacers to run my porsche suspension with the 091 gearbox. I required 525mm - these are 524mm! and use standard bus CVs. Took so long to find a pair as theres only one on each van! anyway...spent some time refurbing them pre-fit.
also spent a lot of time getting the rascal steering rack set up...its just mocked up at the moment until I can work out how to get equal lock each way and how i intend to link it to the corsa rack. Its all fairly straightforward but needs to be carefully worked out to make sure it works correctly.
[/img] |
Covin Darth Admin
Posted: Sun Nov 11, 2007 11:59 pm Post subject: |
Looking good there Rich, pleased to hear you got the drive shaft problem sorted at last  _________________ DARREN
I LOVE RUST ME
www.vwbaywindow.co.uk - - www.covin.co.uk - - www.flat4dubs.co.uk |
Alex (FTS) Jedi Guardian
Posted: Mon Nov 12, 2007 1:08 pm Post subject: |
Nice one mate good to see the rascal rack mounted in-any problems with the brake pedal or servo getting in the way?  _________________ www.faltownskateboards.com |
Posted: Mon Nov 12, 2007 4:27 pm Post subject: |
| nope - all looks striaght forward on that front - only issue is the end of the rack protuding thru the front panel slightly on full lock - but that will be covered by the bumper. The only problem is that is doesnt seem to have much lock on it - hopefully some comparisons later with JPs will show us how much difference. |
Posted: Mon Mar 17, 2008 4:14 pm Post subject: |
some more progress...
spent ages cleaning, primering and shultzing the centre of the van.
final fitted the rack with proper braketry
modified the corsa steering link to bolt onto the rascal rack rubber donut
vauxhall kindly designed the link bar so its adjustable in length so i didnt even have to cut it...just closed it up a bit more and bolted the rack and EPAS all together.
I also finally decided on a dashboard set up so all the hours I put into my golf derived heater blower/matrix to run the original heater tube will be wasted....its up for sale if anyones interested...plug and play front heater set up using original VW pipework.
This means I can do away with all the effort I put into the front duct...diverting flow around the riser tube....which is a good thing As I will get more air to my rad. as more air will get rammed into the duct. i cut it all out and remade it......
my new dash plans also mean these will be for sale.....
911 clocks complete with wiring and the concave cut out from the porsche dash.
PM me if your interested.
i really enjoyed making some decent progress after a long stalemate and other things getting in the way....rekindled enthusiasm means watch this space as the duct is the last bit of upside down modification / welding i will need to do  |
Cleverchap Jedi Master
Joined: 08 Feb 2006 Posts: 356 Location: Middle of the Midlands
Posted: Mon Mar 17, 2008 7:51 pm Post subject: |
| Looking good Rich. What do you want for the heater set up? |
Nice going Rich  _________________ The advice you receive on here is worth the paper it's written on.
Covin Darth Admin
Posted: Mon Mar 17, 2008 8:22 pm Post subject: |
Great work as always Rich
Wish I had some spare cash to buy those 911 clocks
Keep up the good work fella  _________________ DARREN
I LOVE RUST ME
Posted: Tue Mar 18, 2008 7:03 pm Post subject: |
Whats the new dash plans then fella-its all coming together nicely  _________________ www.faltownskateboards.com |
Posted: Wed Mar 19, 2008 10:22 am Post subject: |
cheers chaps - the dash plans are going to be something very different than standard and involving dakota digital......and thats all im going to say for now
Al - ive picked up another job at stithians Res....so looks like i might be down your way soon  |
Posted: Wed Mar 19, 2008 6:02 pm Post subject: |
Dakota digital are good guys and they produce real nice gauges. I had a set in my old buggy and they were great.  |
