subaru ej2.2 in a 1970 bay
evercold
PostPosted: Sat Dec 01, 2007 8:29 pm    Post subject: subaru ej2.2 in a 1970 bay Reply with quote
Right heres go's.
i have had the engine in the van for 3 months, i have now managed to blow 3rd gear in the gear box,so i thought it would be good to put some pics up on here of the engine going back in.
my set up was rad in the back with a heat matrix under the seat,RJES bell housing (this is a great bit of kit ) 1600 gearbox.This did work on A and B roads but when on the motorway doing 70-80 mph the engine temp would rise, so i have decide to mount the rad under neath the van with a scoop to direct the air.
i repalced the gearbox last week so heres a few pics of what i got done today.
any feedback good or bad would be welcomed, as im no engineer and need all the help i can get.
gear box changed and a coat of paint in the engine bay;
put some siver rockwall (i hate fiberglass) on the firewall and sides bit of luck get a bit more light in there.
so today i managed to go form this
to this
having another go tomorrow so a few more pic coming soon Grin
gerrelt
PostPosted: Sat Dec 01, 2007 9:34 pm    Post subject: Re: subaru ej2.2 in a 1970 bay Reply with quote
Nice going there, keep up the good work!
I had exactly the same symptoms with my rear radiator setup.
You have a pool table in your garage?!?! Grin
homepage
VolksRomeo 13033 S 1.4 IE
evercold
PostPosted: Sat Dec 01, 2007 10:13 pm    Post subject: Reply with quote
no i have an engine in my pool room and an understanding girlfriend Laugh Out Loud
gerrelt
PostPosted: Sat Dec 01, 2007 10:20 pm    Post subject: Reply with quote
Laugh Out Loud The engine in the pool room, why didn't I think of that? :smt042
homepage
PostPosted: Sun Dec 02, 2007 11:42 pm    Post subject: Reply with quote
Top work fella and what top bird you must have for being so understanding Grin I want one Eeeek Laugh Out Loud
Have you done any work on the new rad set up yet ?
What you've done so far looks good to me
Keep the pics coming Wink
evercold
PostPosted: Mon Dec 03, 2007 4:21 pm    Post subject: Reply with quote
sundays update.
got the engine support i made this out of 20 x 50 box steel.
got the fuel pump mounted its form a 3.2 jag injection.
got the engine in and all suported, a pig of a job as the rubber mounts had expanded had to get a racthet strap to pull them back in.
thanks to Elusive for the anti vibe mounts now i can get the rad mounted.
evercold
PostPosted: Sun Dec 09, 2007 3:12 pm    Post subject: Reply with quote
The weather down in kent has been crap this week end Sad only managed to get the rad done.
got the rad mounted used some antivibe mounts on the front (thanks elusive) once i get it running then i will sort the scoop/boxing the rad in.
the rad is from TSR and is very thick i have 2, 12" spal fans runing off a temp switch in the rad ,it worked well when it was in the back on A and B roads but the fans were on all the time on the motorway and the temp used to solwly rise when i went over 70 mph.
im hoping this rad will perform well underneath with the scoop/boxing done.
thats my lot for this week end if works quiet should get the plumbing done during the week
