evercold Padawan
Posted: Mon Oct 22, 2007 9:16 am Post subject: rev limiter cutting in at 4500rpm any idea ????????????? |
Hi my ej22 is hitting the rev limiter a 4500rpm,this cant be right, i had my loom converted by tsr so i have no falt dianos, dose any one know how i can convert my loom so i have this (its a 1990 h plate) or any idear what to check/look for why its hitting the limiter so early, m first thought was that it is in limpo mode but would it rev this high?????????????
potholebill Force Sensitive
Posted: Mon Oct 22, 2007 9:45 am Post subject: |
| Thats limp mode , had one done at tsr while back with same problem . found out later that i needed a speed senser that they had cut out. I had to make a speed senser with some magnets glued onto my cv joint and a hall sensor :smt120 Theres some more info on this forum somewhere . |
doppelganger Jedi Guardian
Posted: Mon Oct 22, 2007 1:22 pm Post subject: |
| potholebill wrote: | | Thats limp mode , had one done at tsr while back with same problem . found out later that i needed a speed senser that they had cut out. I had to make a speed senser with some magnets glued onto my cv joint and a hall sensor :smt120 Theres some more info on this forum somewhere . |
not the case with this one because it came out of my van ,which i used for a good yr before that
it certainly sounds like limp home though.
what was it runing like before?? _________________ vwdrc class rep
evercold Padawan
Posted: Mon Oct 22, 2007 2:04 pm Post subject: |
I done over 1000 miles since its been in and its never gone over 4500rpm .
im speaking to rjes at the mo to find out if its possible to get the fault light reinstalled to the loom, im hoping this will point me in the right direction to the fault.
Posted: Mon Oct 22, 2007 3:44 pm Post subject: |
| evercold wrote: | I done over 1000 miles since its been in and its never gone over 4500rpm .
now im wondering why it never did it in mine cos i did over 20k .
kin ell and you havnt had it over 4500 revs ,you wait till you can hit 6500 and why didnt you ring me? _________________ vwdrc class rep
evercold Padawan
Posted: Mon Oct 22, 2007 5:13 pm Post subject: |
thought i would take it easy for the first few miles, then i lost 3rd gear so i had to floor it in second thats how i found out it was only reving to 4500rpm, wasnt sure if its somthing i have done or not .
any ideas droppelganger |
Posted: Mon Oct 22, 2007 5:17 pm Post subject: |
| evercold wrote: | thought i would take it easy for the first few miles, then i lost 3rd gear so i had to floor it in second thats how i found out it was only reving to 4500rpm, wasnt sure if its somthing i have done or not .
im trying to think of a reason it was ok for me and not you,so you have never gone over 4500? _________________ vwdrc class rep
evercold Padawan
Posted: Mon Oct 22, 2007 5:18 pm Post subject: |
no not from day 1  |
Posted: Mon Oct 22, 2007 5:20 pm Post subject: |
| evercold wrote: | no not from day 1  |
you are in for a surprise
have you spoken to richard? _________________ vwdrc class rep
evercold Padawan
Posted: Mon Oct 22, 2007 5:31 pm Post subject: |
yer hes not too sure said he has seen i before and sorted the prob by fitting a speed sensor but my year off engine dont need one and if you diddnt have one and it worked fine that cant be the prob.
i thought the fault light might help, rich he can change the loom and i would like it there for future use so going to sent the loom and get it changed.
i would still like to know if anyones had the same fault  |
Posted: Mon Oct 22, 2007 5:59 pm Post subject: |
the only people ive known with this prob have needed speed sensor,ill ask beanie tommorrow see if he has _________________ vwdrc class rep
evercold Padawan
Posted: Mon Oct 22, 2007 6:14 pm Post subject: |
be great if you could mate
thanks Mr Doppelganger  |
