split_trix Jedi Knight
Posted: Fri Sep 28, 2007 7:28 pm Post subject: engine supporting |
Hi, how do people support their subaru engines in bay vans ?
the reason i say bay vans isnt that i have one i'm just hanging a bus box in a bug and wondering how to use the stock subaru engine mounting points without the use of the gearbox horns as they will be removed,...
split-trix _________________ 52 vwrx |
ricola Jedi Master
Posted: Sat Sep 29, 2007 4:17 pm Post subject: |
Have a look on rjes' site, they have a U shaped cradle that goes from the main rails of the chassis and pick up on the scooby rubber mounts.
If I were you I'd make up something similar that tied into the top damper mounts and the framehorns too. _________________ http://www.ricola.co.uk |
mark-s Padawan
Joined: 06 Mar 2006 Posts: 58 Location: newcastle upon tyne
Posted: Wed Oct 03, 2007 3:27 pm Post subject: |
I cut the engine brackets of a stock bay engine support bar, then welded them to a length box section steel, then used the stock subaru mounts.
Then I made 2 plates with captive bolts & welded them to the bottom of the chassis legs either side of the engine. With the new support bar bolted in place, I took some of the weight off the engine with a trolley jack & measured from the ends of the support bar to the mounting plates. I made 2 T-shaped bits & welded them to the support bar a la rjes U-shaped one. It bolts onto the plates I welded onto the chassis.
I have pics if you want them. |
Posted: Wed Oct 03, 2007 4:58 pm Post subject: |
Basically what i'm doing is making the rear end of the chassis again... so the gearbox be lowered out instead of struggling over the horns...
So the consensus is to use the standard subaru engine mounts..
Does anyone have any pics of where the mounts are ?
chris _________________ 52 vwrx |
Posted: Wed Oct 17, 2007 1:05 am Post subject: |
They are about six inches behind the ends of the frame forks, slightly further apart. You can just see them in this photo http://www.rjes.com/html/rjes_subaru_2_5_syncro_2.html
Mounts parts for Beetles are on my 'to do' list, they have just not made it to the top yet..... _________________ Regards,
Posted: Wed Oct 17, 2007 7:54 am Post subject: |
cheers rich for the pics i now know where they are....
do the engine support bars differ with a shortened sump ?
Posted: Wed Oct 17, 2007 10:47 pm Post subject: |
Ah - that depends what type of shortened sump you have. No for standard sumps with the bottom chopped off, yes for the german 2 piece cast alloy sumps, which don't allow you to fit the Subaru mounts at all (they were designed for Beetles with cantilevered engines).
The one piece cast alloy sumps I'm working on (slowly - I know!) are designed to work as a system with all my other parts, and will fit around the standard mount rubbers and all other cross members. _________________ Regards,
Posted: Thu Oct 18, 2007 7:28 am Post subject: |
So as long as i stay away from hitting the original sump with the support bar your lowered sump should fit ?
how much shorter than the standard sump will yours be ?
Posted: Tue Oct 30, 2007 6:48 pm Post subject: |
Sorry about the delay replying. The sump will give the same amount of ground clearance as the stock VW wasserboxer / type 1. The extra oil has to go somewhere though, so it will mainly use the space between the rubber mounts and oil filter / thermostat. Also, the cast sump comes closer to the bell housing mounting face than the stock one. If your mount does not stick back more than 10mm behind (in a rear engined installation) the bell housing mounting face, then the sump should fit. I hope that made sense?
I have fabricated the prototype bay mount cross member today. Now I need to go and fit it up to my mate's bay project the check whether anything needs fine tuning. Another mate has just imported a splitty shell too, so hopefully I'll be using that to develop a mount for splitties too within the next few weeks. _________________ Regards,
