toadheaddesigns Padawan
Posted: Sat Sep 15, 2007 10:08 am Post subject: |
getting started in 30 mins or so, just picked up the adaptor plate and all is well, ended up getting three of the threads helicoiled, the 4th was fin as had been recut in the past to a deeper pitch and was strong _________________ "Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
"It's not unusual." |
Posted: Sat Sep 15, 2007 2:43 pm Post subject: |
right, i thing the problem is with the selector as trying with and without part 6 on the shifter wasnt working, i could only get one gear but i was still uncertain what that was, with the wheels turning in a fwd motion, the input shaft was turning clockwise
anyway, i started the day like this
and finished like this
I need a new gasket for the nose cone, and i will be trying to suss it all out maybe tomorrow. I must say this weekend has been quite dis-heartening
but on a lighter note my wife has given me her grandads genuine WWII munitions box to use in the car. It will need paint stripping back and repainting but its so cool
Gerrelt, just a question for you. When you fitted the adaptor to your alfa engine, did you loctite the nuts onto the studs? I am using flanged nuts to spread the load a bit, but am considering changing to M10 nylock nuts with washers and locktite them in place _________________ "Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
gerrelt Jedi Master
Posted: Sat Sep 15, 2007 6:06 pm Post subject: |
No, I didn't use locktite. I figure that the Engines are normally bolted to the gearbox without it, so there is no reason to bolt it to the adapter plate with it.
Ohw, I used liquid gasket instead of the paper gasket when I changed my gearbox nosecone. I've driven about 100 kilometers with it now, and it doesn't leak...yet...
Other people used it too, and they said it worked (but don't blame me when you have to pull the gearbox again because of a running nose(cone))...  _________________ homepage
VolksRomeo 13033 S 1.4 IE
_________________ |
Posted: Sat Sep 15, 2007 6:49 pm Post subject: |
cheers fella, thats good to know
as for removing the box when theres a leak....poo happens  _________________ "Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
Posted: Sun Sep 16, 2007 2:46 pm Post subject: |
right...sorted it all out now
it appears that i might have not ensured the box was in neutral when i originally installed the nose cone...but we'll never know now
its all back together and working fine....so engine will be back in by weds, and it can be dropped off the jacks and stands and wheeled out of the garage to start the other jobs
im happier now  _________________ "Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
Posted: Thu Sep 20, 2007 7:18 pm Post subject: and the bitch is back |
engine back in tonight...and trimmed the engine bay
and its getting a bit tight down there now
"Is it common?"
gerrelt Jedi Master
Posted: Tue Sep 25, 2007 6:29 pm Post subject: |
Hey,
I stumbled on some more recent pictures of that blue Alfa beetle:
He changed a few things.. _________________ homepage
_________________ |
Posted: Tue Sep 25, 2007 11:10 pm Post subject: |
that looks great....if mine is 10% as good as that i will be pleased....but i aint aiming for a show car...this will be drivem but will be lairy enough to get noticed!!!  _________________ "Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
Posted: Sun Sep 30, 2007 12:35 pm Post subject: |
did a little more today, and now the car is finally off the jacks.
i also started trial fitting some of the other panels up, like the rear wings
just need to get a new cam cover and then grind off the old mounting points for it so they dont jut out. will need to do a little more sculpting with the notches in the wings, and then with the engine lid. Will also need to fill that bloody horrible hole in the lid too
"Is it common?"
Posted: Sun Sep 30, 2007 7:19 pm Post subject: |
i thought is was riding a little high after i dropped it off the jack...then later realised i had trapped my orbital sander underneath.....so removed this and it dropped a poo load more
anyway, took a few pics of it again..so here goes. I will trial fit the front wings later this week and refit the bonnet..which will need the hinges tweaking to work properly.
here goes
"Is it common?"
Posted: Mon Oct 01, 2007 12:58 pm Post subject: |
sander was fine...but i think a little more clearencing on the inner body mounts will be required, its might close...or i may need thicker spacers
it has actually settled a bit more over night...so that housebrick wont fit under the lower manifold now. I need to play aroundwith the exhauts positioning too as its currently pointing the wrong way!!! _________________ "Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
