gearbox woes...help please
toadheaddesigns
PostPosted: Fri Aug 17, 2007 3:23 pm    Post subject: gearbox woes...help please Reply with quote
i have recently changed the input chaft on my box for my alfa conversion. anyway, putting the bearing back on today i used a drift to hammer it home. the axle at this time was supported on the spring plate. before i did this this there was the usual rotational movement in the axle, and all seemed well. After tightening up the bearing cover etc etc i now note that there is no movement in the axle. It seems as if the axle is stuck rigid and doesnt even move up and down on the spring plate.
what the fcuk have i done.I didnt notice this until it was all back together.
on raising the car on the jacks again the axle turns rotationally internally. but have i fucked it? Is there anything i can do without stripping the lot down again, or have i fucked the box??
i have posted this on another forum, just wondering if anyone has experienced this before
"Doc I can't stop singing The Green, Green Grass of home"
"That sounds like Tom Jones syndrome."
"Is it common?"
"It's not unusual."
toadheaddesigns
PostPosted: Fri Aug 17, 2007 6:19 pm    Post subject: Reply with quote
any ideas?
"Is it common?"
"It's not unusual."
toadheaddesigns
PostPosted: Sat Aug 18, 2007 6:54 am    Post subject: Reply with quote
can any gearbox builders advise?
"Is it common?"
"It's not unusual."
pepper
PostPosted: Sat Aug 18, 2007 9:51 am    Post subject: Reply with quote
I'm not quite sure what you mean? is it the driveshaft itself you were getting back on or part of the gearbox itself?
You talk about the gearbox but then you mention about spring plates so is it the drive shaft itself or the gearbox?
toadheaddesigns
PostPosted: Sat Aug 18, 2007 11:34 am    Post subject: Reply with quote
difficilt to explain. If you leave the axle loose (ie not attached to the spring plate at the hub end) it should be free to move around, left right, up down etc
mine is stuck solid
as an example i would use umagine changing gear with your gear lever...it moves around. Now imagine it stuck solid so you cant change...that wot ive got in the axle
so by reattatching the axle tube to the spring plate there is no movement in the tube so no suspension travel
does that explain it?
if not i can video it on me phone and photobucket the video to explain more
"Is it common?"
"It's not unusual."
toadheaddesigns
PostPosted: Sat Aug 18, 2007 11:42 am    Post subject: Reply with quote
i was putting the whole driveshaft and axle tube back on after removing it to replace my input shaft
"Is it common?"
"It's not unusual."
PostPosted: Sat Aug 18, 2007 2:51 pm    Post subject: Reply with quote
Is this a swing axle? If so the tube doesn't move when it's bolted up to the spring plate.
Can you post a picture of what you're talking about please?
toadheaddesigns
PostPosted: Sat Aug 18, 2007 5:27 pm    Post subject: Reply with quote
will post pics up later
the shaft should pivot at the gearbox end if i am not mistaken...the passenger side one does and i didnt take that one off!!!
the fixed end would be at the spring plate
as the spring plate moves up and down with the suspension, the axle should pivot at the box end
mine dont
if you still need pics let me know and i'll sort some out for you
"Is it common?"
"It's not unusual."
72panelvan
PostPosted: Sat Aug 18, 2007 6:35 pm    Post subject: Reply with quote
put cv's together wrong?
toadheaddesigns
PostPosted: Sat Aug 18, 2007 7:07 pm    Post subject: Reply with quote
swing axle bug
in case people did not know what i was on about i have attached a couple of vids. The drivers side axle is rigid solid, but the passenger side still pivots
any help would be appreciated
the drivers side is the one with the problem
i dont want to take it apart until i know what the problem is so i dont have the same thing when it all goes back togther
"Is it common?"
"It's not unusual."
72panelvan
PostPosted: Sat Aug 18, 2007 7:51 pm    Post subject: Reply with quote
have you touched the CV joint? they tend to go together incorrectly easier than they do correctly. As a result they don't move about as described.
tom
potholebill
PostPosted: Sat Aug 18, 2007 9:03 pm    Post subject: Reply with quote
you need to put differant amounts of gaskets on in between gearbox and axel tube. If you buy a gearbox gasket kit, you get loads of gaskets to use as spacers. If you get my drift.
