ford power!
BUGFEZ
PostPosted: Mon Apr 10, 2006 7:05 pm    Post subject: ford power! Reply with quote
Hi, right where to start...got a 72 bay which was a 1700 but has been fitted with a 1600 engine still retaing original 1700 gear box,got a ford 1800 diesel escort (complete),recieved my engine adapter today also had with it what i think is release bearing extension? but no output shaft, can anyone tell me which output shaft/flywheel/clutch plate to use? any other info greatfully recieved! thanks in advance, bugfez[/list]
PostPosted: Mon Apr 10, 2006 11:16 pm    Post subject: Reply with quote
Welcome bugfez Hello
First thing good engine choice Grin
Mine uses the ford Clutch, starter and flywheel.
Yes that is a bearing spacer you will have received.. Normally you get a longer input shaft with the kit !
Check out this thread for more info as it sounds like you have a similar kit to Steamo.
Enjoy Happy
